Page 1 of 5 123 ... LastLast
Thread: Tacoma brakes
  1. #1
    Join Date
    Jun 2005
    Location
    Tucson, more or less.
    Posts
    1,996
    Default Tacoma brakes
    I thought I'd share a couple of things I've been learning about Tacoma front disk brakes.
    Tacomas are known, rather sporadically, for developing what are mistakenly called "warped" front disks. That is, the brakes begin shuddering on high speed descents, then worsen until the problem is noticeable at lower speeds. Some people experience this at very low mileage; others never experience it at all. We noticed it first with about 100,000 miles on our truck, and replaced the rotors and pads with new Toyota parts. But the problem recently cropped up again, barely 30,000 miles later.
    What is actually happening, I learned, is that the rotors are glazing--material from the pad cooks unevenly onto the rotor, producing the pulsing that feels like warpage. You can see the bluish deposits on the rotor by looking through the wheel. Our left rotor got it bad this time, and quickly ate through what was left of the pad, scoring the disk.
    Word I get from several master Toyota mechanics (including my nephew) is that the problem is Toyota's choice of pad material. No one seems to be able to predict when or if the situation will appear--again, many owners never experience it.
    This time I decided, again on advice, to try a different route. I installed Brembo rotors and Metal Master pads. Choice of rotors was mainly due to the fact that they cost less than factory rotors (despite being from the company that supplies Ferrari). But I'm told these pads should eliminate the glazing problem. I should have a followup report in another 50,000 miles or so . . .
    http://www.stoptech.com/ Has some excellent information on the correct method for bedding in new brake pads to ensure long life and optimal performance.
  2. #2
    Join Date
    Sep 2005
    Location
    Rowlett, TX
    Posts
    127
    Jon, I just replaced mine I had 72K on them, I bought some Drilled Rotors from IRotors and some of the Posi-Quiet Pads. I feel like my stopping has improved but, I will need to see how they last. Tu Compa, Suty
    " The only necessity for evil to triumph, is for good men to do nothing." Edmund Burke
    " I'm not as good as I once was, but , I'm as good once as I ever was." Toby Keith
  3. #3
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    11,879
    This thread is well timed, as I need to address the brakes on my HEAVY Taco. Jonathan from TLC in So Cal is working on a set of better calipers with SSBC. That, combined with better pad material will improve stopping. Then I hope to source a set of crossed drilled or slotted rotors to improve fading and reduce glazing.
    My brake performance at this point is unacceptable, so I need to make changes quickly...
    Scott Brady
    Overland Journal
    D1 | LJ78 | MKIII | FZJ80
  4. #4
    kcowyo's Avatar
    kcowyo is offline Expedition Portal Moderator ExPo Original
    Join Date
    Jun 2005
    Location
    Lander, Wyoming
    Posts
    5,159
    Quote Originally Posted by expeditionswest
    Note to self - Do not ride in front of Scott next week at the ExPo Rally!
    '97 Toyota T100 - some stuff and some stories....
    '85 Toyota FJ6O - fractal cruising
    currently listening to - Jamey Johnson "The Guitar Song"
    recommended reading - Into the Story by David Maraniss
  5. #5
    Join Date
    Sep 2005
    Location
    Rowlett, TX
    Posts
    127
    Quote Originally Posted by kcowyo
    Sadly, I cannot attend this years expo, but , That Note to Self is too funny ,I don't care who you are.
  6. #6
    Join Date
    Oct 2005
    Location
    Hayward, CA
    Posts
    762
    Gentlemen,
    My experience with upgraded brakes on track cars has taught me that cross-drilled rotors offer no significant improvement in performance while making it *much* more likely that one will experience severe rotor cracking in much less time than with solid or slotted rotors. The problem is that the cross-drilled holes create many little points on the rotor where stress is magnified and uneven. Eventually, after many heat cycles, the holes will develop small cracks. These cracks grow until they meet other cracks. Before you know it, you have a severe crack along the rotor surface from the inside to the outside edge of the rotor. When this happens you'll experience severe vibration and loss of braking effectiveness. You do *not* want this to happen when you're out in the middle of nowhere, and spare rotors are very heavy parts to carry with you.
    I would respectfully suggest that you stick with OEM or aftermarket solid or slotted rotors, and stay far away from cross-drilled rotors of any kind.
    -Adam
    2006 Toyota Tacoma
  7. #7
    Join Date
    Sep 2005
    Location
    Rowlett, TX
    Posts
    127
    Quote Originally Posted by asteffes
    Gentlemen,
    -Adam
    OOPS, Too late know I have Drilled and Slotted. Guess I will need to keep a eye on them. Thanks for the info. Tu Compadre, Suty
  8. #8
    Join Date
    Jun 2005
    Location
    Posts
    1,996
    Another tip: Use your parking brake frequently. The ratcheting mechanism is what adjusts the rear brake shoes on Tacomas. Infrequent use of the parking brake might put extra stress on the front brakes, exacerbating the glazing problem and causing unbalanced braking.
    Scott, maybe you should be the first to swap a set of ceramic disk brakes off a Porsche Carrera into a Tacoma . . .
  9. #9
    Join Date
    Jun 2005
    Location
    Prescott, AZ
    Posts
    3,027
    I must be one of the lucky guys. 128,000 miles on the original rotors. Maybe because I have a manual trans?
  10. #10
    Join Date
    Oct 2005
    Location
    Hayward, CA
    Posts
    762
    Quote Originally Posted by BajaTaco
    Dealers and brake shops are fond of getting people to spend more than they should on brake jobs. I almost always hear that one should replace the rotors when changing the pads, but this isn't necessarily true. If you're sticking to the same pad compound, or moving to one slightly more aggressive, keeping the same set of rotors shouldn't cause any problems.
    I tend to think one should replace rotors only when there are signs they are at the end of their lifespan. That is, when they show lots of microcracks on the surface or if they have worn past the factory-specified wear limit.
    2006 Toyota Tacoma
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
