Thread: DIFERENTIAL problems
  1. #1
    Join Date
    Aug 2006
    Location
    Laredo ,Tx
    Posts
    803
    Default DIFERENTIAL problems
    the bearing on my cherokee chrysler 8.25 rear diff were changed because of noice,, when they took them out they were shot,, so got replaced, 2 days ago.
    now im getting some bas sounds ,,damm. maybe they left a pair of pliers in there.
    it sucks. should of done it myself....
  2. #2
    Join Date
    Nov 2005
    Location
    Bristol, Pa
    Posts
    1,643
    Which bearing/s were replaced?
  3. #3
    Join Date
    Sep 2005
    Location
    Scram Diego
    Posts
    5,025
    On the Bright Side..........!
    You may come out of this with a new pair of Pliers!
  4. #4
    Join Date
    Aug 2006
    Location
    Laredo ,Tx
    Posts
    803
    Quote Originally Posted by John B
    The 4 bearring , wheel bearing were fine
  5. #5
    Join Date
    Aug 2006
    Location
    Laredo ,Tx
    Posts
    803
    Quote Originally Posted by Scenic WonderRunner
  6. #6
    Join Date
    Aug 2006
    Location
    Seattle, WA
    Posts
    252
    Quote Originally Posted by LUISJG
    pull the cover. the tech may not have re installed the cross shaft retaining pin. the noise that you may be hearing is the long cross shaft being grounded by the pinion and ring gear.
    another cause could be that the adjuster nuts weren't set properly and your bearing preload and backlash isnt correct which can cause nasty sounds as well.
    just a couple of cause that come to mind.
    steven
  7. #7
    Join Date
    May 2006
    Location
    Atlanta
    Posts
    1,765
    Get under the truck right now before you drive it again and see if the pinion is loose and wobbling around. Might have to put the in neutral to get the load off the drive shaft. If you can't turn it a little it has tension on it.
    The Pinion nut on many axles is considered a 1 time use item. If they pulled the pinion to inspect the bearings there is a chance they half assed the job and reused the nut and it loosed up on you.
    If you find this is the problem then tighten it to about 140lbft and see if the noise is gone. No noise then go get a new nut and tighten it to about 160-170lbft (its new it will take more to turn then a used one) and call it good.
    Now before you all freak out...yes you should adjust that nut with spinning preload BUT to do that you have to pull the axles out. If the set up was good 140lbft should keep it plenty tight but not crush the "crush sleeve" any more then it already is. It generally takes about 200-250lbft to effect the crush sleeve.
  8. #8
    Join Date
    Aug 2006
    Location
    Laredo ,Tx
    Posts
    803
    WELL after reading all this I think they did a crap job, .
    im getting also vidration at high speed wich i didnt have before this repair
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
