Page 1 of 3 123 LastLast
Thread: Cracks in rear cross members
  1. #1
    Join Date
    Sep 2008
    Location
    Canberra Australia
    Posts
    38
    Default Cracks in rear cross members
    I was giving my 1993 FG439 chassis some paint prior to starting on a new camper body and I noticed cracks that start between the lower rivets in the cross members at the rear of the truck.
    Cracking issues were discussed in the FG fleet mechanic interview thread.
    The concerning bit is that these cracks are only visible from above and are easily missed. Here are some pics:
    Front Right
    Rear Right
    Rear Left
    Front Left
    My FG has done about 38,000 km, it had a tough time as an overloaded fire truck for the first 9000 km.
    I am now pondering how I "plate the cutouts at the end and weld it all together so that it becomes 1 piece."
  2. #2
    Join Date
    May 2008
    Location
    Cairns FNQ
    Posts
    360
    I cut mine right out and replaced one with a Volvo X member, the other i just ground out & welded. both are still fine.
  3. #3
    Join Date
    Aug 2009
    Location
    Brisbane, Qld, Australia
    Posts
    108
    I'm not much help with the repair but I've joined all those inspecting their chassis this morning and have a question about the pics. I think I can see something at the start of each crack, looks to me like a small weld. Am I seeing it correctly? Not present in mine (later model?) but could help explain why your cracks have occured in those places.
    Don't forget its high tensile steel when welding. A trip to the wreckers may help.
  4. #4
    Join Date
    Sep 2008
    Location
    Canberra Australia
    Posts
    38
    Yes 2 small spot welds on each one.
    I will post a close up of the worst crack later.
  5. #5
    Join Date
    Jan 2008
    Posts
    2,183
    For those of us who don't have the luxury of looking down on our crossmembers from above, can you tell us if you can feel those cracks by reaching up from below and running a finger or finger nail across that area?
  6. #6
    Join Date
    Aug 2009
    Location
    Posts
    108
    Quote Originally Posted by kerry View Post
    have you tried a mirror and a bright light?
  7. #7
    Join Date
    May 2008
    Location
    Cairns FNQ
    Posts
    360
    Quote Originally Posted by gait View Post
    They seem more like mild steel to me.... Nothing like the chassis of yore.
  8. #8
    Join Date
    Jan 2008
    Posts
    2,183
    Looks like it's cracking right thru the center of the rivet holes. Have you look from below at the crossmember where the two top rivets go thru it?
  9. #9
    Join Date
    Sep 2008
    Location
    Canberra Australia
    Posts
    38
    Here is a close up, it will give you some idea of where you might feel the crack with your fingernail if the crack is bad.
    Thanks for the comments on Volvo bits Engineer, do you have any tips on which Volvo model I should be looking for.
    I should point out that the cracks only became apparent after I had attacked the area with a wire brush attached to an angle grinder.
    If you don't have access from above to inspect your rivets it might be possible to take a photo of the area with a small digital camera that has a flash.
  10. #10
    Join Date
    May 2008
    Location
    Cairns FNQ
    Posts
    360
    I'll have to dig for the receipt, let you know tomorrow. I'll take some pics at work.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
