Thread: Hitch reciever
  1. #1
    Join Date
    Oct 2009
    Location
    Virginia, USA
    Posts
    915
    Default Hitch reciever
    Looking for a hitch/ reciever for my gen II. I want the one that just bolts on behind the rear hook like everyone else has. Anyone know where to get one and how much? Thanks!
    J.W.
    Build thread http://www.expeditionportal.com/foru...e-build-thread
    95 Monty LS with 33 10.50 KM2s, air locker, winch, snorkel, sliders, bottle opener, and stuff...-EMT,Auto Tech, US ARMY Survival and land navigation specialist, US ARMY VETERAN 1st CAV 1st BGD COLT Team 3
  2. #2
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,294
    4crawler.com can make one for you.
    He made one for me and should still have the drawings/plans to remake one.
    This is one that bolts into place using the 4 stock bolt points in the center of the bumper and has no drop to it unlike most other hitches which require you to loose alot of rear end clearance (4-6").
    1989 SWB Montero (3.0L v6, rear LSD), 33" mudders
    1996 Montero SR (3.5L v6, rear Locker), 35" mudders, 3.15:1 xcase crawler gears
    Build Thread: http://www.expeditionportal.com/foru...su-build-up...
  3. #3
    Join Date
    Oct 2009
    Location
    Virginia, USA
    Posts
    915
    Thank you sir. I've sent him an email regarding one. any idea on the price?
    J.W.
  4. #4
    Join Date
    Jun 2007
    Location
    Loveland,CO
    Posts
    259
    Check out "Sure Pull" that is the brand of mine. I have had it for years and I am not sure how much I paid for it. This is same as mine. www.hitch-web.com
    http://www.hitch-web.com/vhitch.asp?...D=20512&BPID=6
    Hope this helps some.
    2000 Montero. Lockers front/rear, lower gears, stuff inside, and tent on top.
  5. #5
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,294
    Quote Originally Posted by scrubber3 View Post
    Sorry it was a few years back so I don't recall the price off hand. Plus mine was sort of the prototype / beta version and also metal prices have fluctuated wildly since then so I suspect his pricing will be different now.
    One other thing... I had him design mine primarily as a snatch point. I'm not sure how much weight the hitch of this design can handle since it only bolts into the 4 stock bolt points which would bear the brunt of the load straight backwards versus a typical hitch which bears it on the sides where it usually is attached and not just the front center area. Questions for a design engineer to look at and answer if you plan to use it for towing.
  6. #6
    Join Date
    Oct 2009
    Location
    Virginia, USA
    Posts
    915
    I do plan to tow a small boat. Nothing a dodge neon couldn't tow! I have the plate with the (eye-hook) setting there now which I am sure would be fine for recovery. I just need to get my brother and mines boat to some muddy places at times. I really am thankful for all of the help!
    J.W.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
