Whoa....
That was a lot of work and you did a great job (! wow ! ! !), but you're right, that's very labor intensive.
I sure don't think I could have gotten that to work.
Whoa....
Cheers,
Frank
____________________________________________
"airsotts-narf"
Save a Life, Adopt !
Redline wrote: "no ring, no bling, bada-bing" ( http://roadtraveler.net/goodbye-bling-rings/ )
Just came across this, today.
Here's another German application using the road case method, but in a modular arrangement : http://www.ququq.info/
(not inexpensive, but then one could build this at home...)
Cheers,
Frank
"airsotts-narf"
I am glad you started a thread for the Sprinter.
We too miss the Tiger, and I was recently tempted by a CX on the east coast.
With a +1 on the way, I have thought about gutting the interior of our SMB. But that, as you know all so well, is a bunch of work!
Robb
KI6OVI
1994 fzj80-sold : 1970 fj40-sold : 1998 UZJ100
1995 SMB 4x4 Diesel EB (keeper...for now)
Bella Adventures
Thanks for the link. I think the modular cases have a lot of potential for storing camping gear. They're relatively easy to make, surprisingly inexpensive, not "that" heavy and super tough. I used them to haul expensive equipment around the U.S. for years in a previous career. They outlasted every vehicle we used to haul them.
One of the projects still remaining on the Sprinter is building a 2'x3'x1' road case to sit where the black rug is in this photo:
It'll have a removable top and connect to the aircraft track along the floor. Inside will be a shower pan, shower curtain, etc. to serve as our indoor shower.
You're very welcome. I thought it good food for thought. The statements "relatively easy to make" and "surprisingly inexpensive," not to mention "super tough" and the examples, really drive home that this is a method to be considered strongly; the first two especially![]()
That is an amazing idea ! ! !
I've collected a large number of road case construction interior photos, but not seen that before. That's going to be a very useful addition.
By the way, the design for ours will need to span across the aisle to make the sleeping platform. With the baltic birch only method, the plan was to have a panel/s that is held to one side by piano hinge and then flips over the span to rest on a support rail. With the road case method, I've yet to come up with something to do this. Have you seen anything, HMR ?
Cheers,
Frank
"airsotts-narf"
Mike Hiscox
2007/2012 custom Jeep Rubicon expedition motorhome
2004 Jeep Grand Cherokee
2006 Honda PS250 Big Ruckus Expedition Scooter
1996/2002 Honda XR600R highly-modded
Tacoma - For Extended Overland Travels
2012 FWC - The TARDIS
Trip Reports - Travels with Hadley
-Nathanael
Large Format Photography
www.KuenzliPhotography.com
Yes. One of our original sketches used a similar platform for the bed. I don't know how big of a space you need to span but if the width is, say, 3' or less, I would use 1/2" Baltic Birch (see note #1 below), laminate both sides with ABS and use 1/2" "U-Cap" extrusion for the edges. On the edge with the piano hinge (see note #2), I'd drill completely through the wood for each hole (you could also do every other hole depending on piano hinge) and use #8-32 x 1/2", stainless steel, pan head screws with a matching T-nut on the other side. With a little loc-tite on each screw it should withstand many miles of washboard roads. Also be careful when tightening any fastener on top of the ABS. The plastic will discolor and warp if it gets squeezed too hard.
Note#1- I purchased our plywood from a specialty shop so I could get a "true" 1/2" thickness. Home Depot and Lowe's usually sell their ply in 15/32" thickness. When laminating both sides of a sheet with ABS it's probably better to use the 15/32". The extrusions can be a tight fit when trying to overlap two sheets of ABS and a 1/2" thick ply. It's always good to experiment with a little section, first, to ensure the right fit.
Note#2- Just a reminder that there are a ton of different piano hinge sizes/configs available. You don't have to stick with the standard width offered by the road case suppliers. The standard size will work great for what you want to do but you might find something else that works better. Aircraft Spruce has a nice selection of piano hinges.
Finally, we ditched the idea of the plywood bed base when my wife suggested an Ikea slat frame. This was probably the single best design change we made. If there's anyway to fit this into your project, DO IT! I can't express how much more comfy this setup is.
The frame:
Mike- Your Sprinter, like your Jeep, is a complete mind blower. Thanks for sharing both builds (not to mention your other cool builds) with us. Just FYI- The Sprinter was probably #5 on our list of "next vehicles". The first time I toured your Sprinter it moved up to the top. It was a big motivator in our move towards the "T1N Can".
