Page 1 of 2 12 LastLast
Thread: 2011 VW Touareg announced
  1. #1
    haven is offline Expedition Portal Moderator Expedition Leader
    Join Date
    Jul 2006
    Posts
    8,542
    Default 2011 VW Touareg announced
    For 2011, the VW Touareg receives a significant makeover. The new design is about 450 lbs. lighter than the 2010 Touareg, while improving torsional rigidity slightly. The new Touareg is more aerodynamic as well.
    Here's a drawing of the new Touareg, showing its revised sheetmetal and grill.
    The Touareg will continue to be available with the 3.0L turbo diesel engine. The reduction in weight and more slippery shape results in a 31 mpg highway rating, up from 25 mpg in 2010. Unlike VW's 4 cylinder diesels, the V6 diesel uses diesel exhaust fluid to help control emissions.
    VW also has developed a gasoline-electric hybrid version of the Touareg. All engines (V6 gas, diesel and hybrid) will be sold with an new 8 speed automatic transmission.
    The Touareg's standard all-wheel drive is called 4Motion, which includes a Torsen limited-slip differential. The standard AWD can be switched to "Off-road driving" mode, changing the electronic monitoring systems for a loose surface, and activating Hill Descent Assist. Note that there is no low range setting in the standard AWD for 2011. (The 2009 Touareg had a standard locking center diff and low range. The locking rear diff was optional.)
    The 2011 V6 TDI can be ordered with the optional "Terrain Tech" setup, which includes a stronger transfer case with low range, plus locking mode in the center and rear differentials. This locking ability is referred to as 4XMotion in VW literature. Selection of low range and locked diffs is made with a dial on the dash.
    Potentially of use when offroad is the new Area View option, which displays the view of four cameras on a 6.5 inch touchscreen in the center of the dash.
  2. #2
    Join Date
    Jul 2006
    Posts
    8,542
    A few more details about the new Touareg:
    length 189.0 inches (increase of 1.7 inches)
    wheelbase 114.2 inches (increase of 1.7 inches)
    width 76.0 inches (same as 2010)
    height 67.3 inches (same as 2010)
    Engine choices for USA
    -- gasoline direct-injection 3.0-liter V6 (280 hp, 266 ft-lbs)
    -- turbo diesel 3.0-liter V6 (240 hp and 406 ft-lbs)
    -- gasoline direct-injection 4.2-liter V8 (366 hp and 328 ft-lbs)
    -- supercharged gas V6 and electric motor hybrid (380 hp and 428 ft-lbs)
    All engines are paired with an 8 speed automatic
    The 2011 Touareg should appear at VW dealers early this Summer.
  3. #3
    Redline's Avatar
    Redline is offline Overland Training Alumni
    Likes to Drive and Ride
    Join Date
    Nov 2006
    Posts
    3,378
    all engines are paired with an 8 speed automatic
    8!
  4. #4
    Join Date
    May 2009
    Location
    Arvada, CO
    Posts
    590
    Default !
    oh man that is sexy! wish i had a better income!
    1994 Montero SR. 32/11.5 Build in progress
  5. #5
    Join Date
    Apr 2008
    Location
    E. Sierras
    Posts
    550
    hope they sorted out all their reliability issues. Not pretty when a 50-60K vehicle is on the side of the road regularly
    '87 &'10 4runner
    '10 Tundra
  6. #6
    Join Date
    Aug 2008
    Location
    N.E. Pennsylvania
    Posts
    22
    Default Not for me!!
    Couldn't wait to get rid of my '07. Worse vehicle I ever owned. Battery is under drivers seat, two hours to change oil @250 a pop. Constantly in the shop. Mine was a loaded V-8. Sweet when it ran...... Read the owners forums first!
  7. #7
    Join Date
    Apr 2008
    Location
    E. Sierras
    Posts
    550
    Quote Originally Posted by mobilguy66 View Post
    So sorry you had to deal.
    My wife and i were literally hot on an 09 tdi toureg until i started doing research(forums) and talking to actual owners of touregs. they are VERY problematic and it is not isolated to one area of the vehicle. TOO BAD- it is a beautiful idea and styling is spot on.
    '87 &'10 4runner
    '10 Tundra
  8. #8
    Join Date
    Jun 2009
    Location
    Alexandria, Va.
    Posts
    1,862
    You can keep it. As an owner of 3 VAG products, I have switched to Subaru and will never go back. The Touareg is a terrible truck. Lease it, never own it. Lease gets you full warranty coverage and you can ditch it before it gets expensive. If only tires and brakes were covered also.
  9. #9
    Join Date
    Jan 2010
    Location
    Houston, TX
    Posts
    1,294
    It's a sedan, people. Trunk turned 90 degrees up. Don't be fooled.
    They actually put a battery under the driver in that model?? What?!
    AND look at the photo, carefully. I am SO SURPRISED no one called them on their ridiculous trunk space. It's what, 14 inches long, now?
    If there are any VW engineers on this forum - PLEASE GET YOUR WATER PIPES TESTED FOR LEAD POISONING - YOU'RE FUNCTIONING LIKE ANCIENT CITIES THAT USED LEAD PIPES/SEALING MATERIAL!! You're slipping, but you don't realize it.
    Have you noticed that? The trunk space getting shorter over the last several years? My '93 car has more trunk space than Touareg shown here.
    Stephanie
  10. #10
    Join Date
    Mar 2009
    Location
    Tucson
    Posts
    32
    Reminds me of the old Bugs where the battery was under the rear seat. I was driving one once and a big guy was sitting in the back and he shorted out the battery on the metal springs of the seat and that started the stuffing on fire while we were at a stop light. We piled out of the car, tore the seat out and stood there laughing at ourselves while the people stuck behind us were honking their horns.
    Chad
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
