Page 15 of 16 FirstFirst ... 513141516 LastLast
Thread: New adventure Toy(ota) in AZ
  1. #141
    Join Date
    Nov 2010
    Location
    Phoenix, AZ
    Posts
    106
    Wire cup + knee. I had a similar experience with a chainsaw years ago. Got *very* lucky. But yeah, character-building, right?
    I take it you've decided to go 1-piece on the prop shaft, then? Does this mean the risk of damage and reduced clearance aren't enough to overcome the benefits from simplicity and (I suspect) cost savings? If you're going to have the driveshaft custom-made, why not ask the professionals what they would recommend? If you'd like a second opinion, there's a thread up in the In-Progress Adventures section with a couple guys up in Canada did a lot of BBQing in BC. They ended up getting a custom axle built on the road and seemed very pleased with the service. Shop name is in the thread. Couldn't hurt to call, right?
    EDIT: Here's the page in that thread where they mention the axle shop. Worth a shot.
    Brian Driggs | Gearbox Magazine | Gearheads United
    1989 Dodge Raider & 1991 Mitsubishi Galant VR4
  2. #142
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    The shop I'm planning on using is very close by my home and office, I already got his opinion. He was the first to suggest going one piece. I was reluctant at first, but after thinking it over for days, talking with a few other people, etc., I've come to the conclusion, try it. If it becomes a problem, then I'll just switch it back to two pieces at that point. The wheel base is short enough and the shaft only sticks down at droop situations. The low point is still the center of the axle, by a long shot.
    -Jon
  3. #143
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    From this -
    To this -
    in just a few HOT hours of work. I got the car loaded up on the trailer and ready to take to the driveshaft shop. The tricky part this weekend was finding a new flex hose, needed one a bit longer than what I had. After a lot of diggin around on the internet, I found the length numbers I was looking for from RockAutos sight. I ended up buying a 1st gen Tacoma 4x4 rear hose, about 2-2.5" longer than what I had, perfect.
    -Jon
  4. #144
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    Just picked up my custom made 1 piece driveshaft from TAD in Phoenix, AZ. I'm keeping my fingers crossed that it fits under the floorpan, under all situations. I guess I'll pull the springs out and find out about full compression, droop and articulation.
    -Jon
  5. #145
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    And the project of getting an F-code rear axle into Carlos is done... (well, mostly) 20 minutes or less of work got my new TAD 1 piece drive shaft installed. The exhaust is going to need a little moving about, but it's fine for now, doesn't touch at full droop, sitting still, but it's VERY close. The car is completely different, no whinning from the back end, peppy excelleration, etc.. Can't wait to get it in the dirt, see how the LSD really feels.
    -Jon
  6. #146
    Join Date
    Feb 2008
    Location
    PDX
    Posts
    755
    Sweet! and if the driveshaft hits the exhaust every now & then, it's just to knock the dirt off
    -Keith- general license ham
    '88 4runner SR5 - 3L 7MGE swap - 4.88 front LSD / rear E-Locker - 33x10.5 BFG KM2's - NWMP 14 gal aux fuel tank
    Corax's 1st gen RN61 4runner
    "In short: we used everything we took and didn't miss anything we didn't take. Which does not mean we really 'needed' everything we took." - RadioBaobab
  7. #147
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    This weekend, I didn't do a whole lot of work on the car, but I did go buy a salvage yard set of parking brake cables from a van to match the axle. One side fits decently, but the area where the hard clamp mount goes is in a different place on the housing. Not too big a deal, just clamped down where I needed to. The other cable is almost 24" longer than it needs to be, but with some creative routing with smooth curves and a flexible strap to pull it away from the tire seems to make it fit. Last bit is just to get the cables adjusted to actually hold decently.
    -Jon
  8. #148
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    I'm going to have to get the cables to mount as designed, using the cable end clamps. I've got one side modified for now, the other side is going to reguire some fabrication, but it'll be worth it. I don't like not having a parking brake that works really well. When I'm playing in the dirt, sometimes it's very handy for helping the back end swap over quickly for hair pin turns. Plus, it sucks having to turn the engine off just to stop for a minute.
    -Jon
  9. #149
    Bad ***
  10. #150
    Join Date
    Feb 2009
    Location
    Phoenix, AZ
    Posts
    290
    Adjusted the panhard bar last night, not bad for eye balling it the weekend earlier. I only had to change it by 1/16" to get the axle centered under the body. This morning I dropped the car off for an alignment. It's the one thing that seems to plaque using a car like a truck, the front end needs aligning about every 6 months. But, then again, maybe if I used my Ford Exp. as hard as I use the Celica, then it might need aligning more often too.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
