Who has ran a Detroit rear locker on stock axles on a d2?
Problems? Thoughts? How strong are the factory axles?
I've run a detroit in the rear of my 04 D2 since the summer of 2008 with no problems. Im running 265/75 Goodyear duratrac's with a 2 inch rte lift. Its all armored up (sliders, front and rear bumpers, 12000lb winch with steel cable) so its pretty heavy. Drove it to Moab and back from NC in September 2008. Wheeled it like the devil and didn't break an axle. Went up Moab rim...dragging the truck through every obstacle. Every once in a while the rear detroit will unlock and make a loud bang when in reverse and turning hard. It sets off all the abs and srs light on the dash. turn truck off and back on .....all lights go away.
I think the material the shafts are made of in D2's are much stronger than that in D1's.
I have been very happy with my set up overall. The front axle is currently open diff but the traction control seems to operate the front axle pretty well. Will more than likely add an arb air locker to the front at some point.
I'm going to Uwharrie in april......so we will see how the rear shafts hold up to the extra ponies since the cammed up 4.6 build.
Justin
2004 Disco 5.0
Just beware that if you do break an axle it will more than likely take out your Detroit.
Brainzzzz! We want your brainzzzz!
That's the first I've heard of that. What's your source?I think the material the shafts are made of in D2's are much stronger than that in D1's.
I got a bottle of Aloe after getting sun burned. It says "apply Liberally"... I'm not sure if this means other people pay for it and I use it, or I am to force other people to use it even if they dont want to because it's what I think is right for them?
and don't forget, it is semi-floating, not a full floater rear axle setup, so the time involved to fix is greater as well
Mainly experience, Ive broken a handfull of factory shafts in a D1 and D90 from stock to full mod, but I have never broken a D2 shaft and have flogged it pretty good. Time will tell but with the shafts being fairly relative in size and spline count, I would imagine the metallurgical properties of the D2 shafts are better, or shall I say improved, over that of the D1 or D90.
Justin
2004 Disco 5.0
