I picked this one up at a Baja swap meet 20 years ago for $5. It works like a charm.
...there are ads in the back for a hardware store selling Coleman gear that shows that tank style. Not sure when they changed, but that is the era....
I thought I was a pretty involved collector with a half dozen stoves a handful of lanterns and a couple old coolers, but then I see pictures like this and know I'm pretty amateur
I'm really bummed that Old Town Yucca seems to be down, he had a very cool online museum with all the different models.
Question for you vintage Coleman users, now I just use the Coleman fuel to run these, but as a kid, the old man simply used pump white gas, Amoco as I recall. Is there a problem with using today's unleaded, or are there too many other additives that will clog the gear?
Not really. Modern unleaded gas will work just fine for a long time before the generator carbons up. When it does, if you're the handyman sort you can clean the generator and put it back in. If you're not, just replace it. You can buy a whole lot of new generators with the money you save by not buying lantern fuel (naphtha), which is currently around $10 a gallon.Is there a problem with using today's unleaded, or are there too many other additives that will clog the gear?
