Thread: Zombie/Burning Man?
  1. #1
    Join Date
    Nov 2009
    Location
    Denver
    Posts
    126
    Default 4wd diesel on CL
    No affiliation, but local if someone wants a scout
    http://denver.craigslist.org/cto/1703307194.html
    This would be an ideal vehicle for Burning Man!
    Highlights:
    4WD
    Turbo diesel has ~80K miles
    Magneto-electric retarder braking system
    Good tread on tires
    Fun as heck to drive!
    This is truly a unique vehicle.
    The original owner spent about $75K building this beast to sell ski wax
    and tow his boat around in the mountains.
    It's four wheel drive! Well, it has dualies in the back, so I guess that makes it 6WD? LOL!
    The conversion was done by a company in Utah. They completely removed
    the front end and put in a Dana 60 front axle, zombie proofing, American transmission and
    transfer case. I'll even throw in Four wheel low for no additional cost to
    you, the consumer!
    I've taken it to Moab several times and driven around in the sand...
    never got stuck.
    It has a Fiat 336 Cu/In turbo diesel with about 80K miles.
    A really cool feature is the electro-magnetic retarder. This sits
    around the drive shaft and uses electricity to slow the vehicle down
    without using the brakes. It works very well. Coming down from the
    Eisenhower tunnel toward Denver I can hold 55MPH without gearing down or
    touching the brakes.
    The front half of the box has a table/bench combo that converts to a bed.
    It also has a propane heater on a thermostat to keep the inside warm.
    This isn't really an "RV" per se since it doesn't have a kitchen or sink.
    But it has a propane tank for the heater so a stove would be pretty easy to install.
    The front half of the box is also covered from floor to ceiling in brownish shag carpet,
    so it's got that going for it!
    The back half has diamond plate on the floor and plywood walls with
    securing straps on one side.
    There is a ramp that pulls out of the back to allow easy loading of gear.
    You can ride a motorcycle up it and into the back of the truck if you're
    brave.
    The side door has stairs that fold down for easy access.
    '85 4runner - DD, trail rig, and expo vehicle
    '85 4runner - currently bricked and for sale
    '86 4runner - needs a tune-up and for sale
    '81 Centurion Signet - it's a bicycle
    The D. J. Marcus Law Firm LLC - Law for Small Businesses
  2. #2
    Join Date
    Jan 2008
    Posts
    2,183
    It'd be nice to see pictures of the conversion to 4wd. Quite a unique vehicle.
  3. #3
    Join Date
    Dec 2008
    Location
    Chico, CA. USA
    Posts
    87
    I emailed this guy with a bunch of questions and as usual with craigslist I got a very vague response. What he did say was it is running hot, I don't know for how long or how hot but that worried me. I was ready to drive from California to buy it. He also said it's an Iveco truck.
    95 Montero SR
    05 Nissan Frontier 4x4
    78 4x4 Dodge Transvan
    05 Honda CRF 450x
    02 Polaris RMK 800
    96 Yamaha Phazer
    02 Roketa 800
  4. #4
    Join Date
    Mar 2007
    Location
    Montreal & San Francisco
    Posts
    5,425
    what is a "Magneto-electric retarder braking system "?
    Christian
    CTO Expedition Portal
    www.expeditionportal.com
    www.2aroundtheworld.com
  5. #5
    Join Date
    Jan 2008
    Posts
    2,183
    Quote Originally Posted by 2aroundtheworld View Post
    I've got one on my Bluebird Wanderlodge. They're typically called just retarders or electric retarders. Mine is a huge device mounted around the driveshaft. (it's really bolted to the frame and the driveshaft attaches to the front and back). It's huge, probably weighing 300+ pounds and appears to be constructed with spinning magnetic plates. When electricity is provided to it, it slows down the bus without having to use the brakes. I imagine it to be a huge DC motor running backwards. It's very effective. On steep downgrades I don't need brakes, just the retarder. They are also not cheap. It cost the original owner of my bus about $5k to have it installed.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
