78Bronco
I have driven with both LSD's and Detroits in the rear of unloaded and partially loaded F150's with V8's in the snow and ice. The south coast of BC doesn't see a lot of snow but when it does snow it's heavy/wet and usually a good dumping.
The old '78 F150 flatdeck had a detroit in it with 35" bfg MT's. We got a 12" dumping and at first the traction sucked, so I shovelled some snow on the deck and dropped the tire pressure 10 psi and violla I have traction again. Definetly having the auto trans helped to allow unloading of the drive line to disengage the Detroit and allow for easier steering on snow/ice. I made it everywhere just fine in 2wd and only really needed four wheel once or twice when creatively parking. If I felt the rear end starting to slide I took my foot out of it and it would stop sliding and I could hear the detroit disengage.
Same deal '96 F150 with a LSD, never had any issues with the rear end swinging out or understeering uncontrolably that couldn't be adjusted to or fixed by adding some weight and dropping pressure.
My 2004 F150 had great all terrain goodyear wranglers, lsd and a few hundred pounds in the back and it went up into the mountains just fine on completely unplowed snow covered highways the morning after a huge dump of snow. They closed down the main highway so I had to take the smaller back road type highways through the coastal mountains and had no problems in 2wd.
I wouldn't hesitate to run a locker or lsd. If the road is that slippery you are going to notice before any thing bad happens. Unless you drive a 90 Montero
