OzX
A couple of weeks ago I was on a short run and as usual I put my Stauns on the valve stems at the trailhead to air down.
I usually pay more attention to them so that they "stop" at the selected PSI (14psi) by pulling on them, but I got distracted and just let them stop by themselves.
When the Stauns 'finished' all tires were at 10 psi (I always check afterwards with a tire pressure gauge). Even though it was lower than I usually run them at I figured what the heck and let it go.
Air temp was about 70 degrees and the elevation I'm guessing at the trailhead is about 4500'.
NOW 3 hours later after wheeling moderately on the egress, back at the trailhead the PSI at each tire was between 18-20 PSI. YEs the ambeint air temp was up to about 80-82 degrees and I imagine the action of wheeling will warm the inside air of the tires and increase the PSI.
WHAT I want to know is it possible to figure the TRUE PSI of what your tires are doing, no matter what the external temps and/or elevation is.
Visually the tires felt fine and had a nice bulge when aired down.
ANYONE else ever notice this discrepancy between PSI after airing down at beginning and end of a run. Is there a good rule of thumb here?
THANKS
THANKS
