Page 6 of 84 FirstFirst ... 456781656 ... LastLast
Thread: The Four Wheel Camper Build
View First Unread
  1. #51
    Join Date
    Feb 2009
    Location
    camano is, wa
    Posts
    587
    I have used a buddy heater @ 4500' no problems. Worked great in the back of my truck shell not sure above that altitude. You can purchase adaptors to hook up a buddie heater to differant sizes of bottles just be sure to purchase a filter that connects between the buddie heater and fuel feed line.
    Anywhere I roam where I lay my head is home.... Metallica, the black album.
    www.northwestoverlandsociety.org
  2. #52
    Join Date
    Jun 2010
    Location
    Escalante, UT
    Posts
    11
    Quote Originally Posted by waynemaple View Post
    I think if you order the furnace package it comes with a CO and smoke detector. It is also a forced air unit with electric fan and thermo, already vented. With the shell model the cabinet is only about 14inches or so high, or my info could be wrong. But with that addition it should not weigh that much, maybe 50 lbs. I've been planning my Finch build for about 4 months and this is very helpful. Any thoughts on removable dinning area? Sink, stove and such that can be placed outside of camper. I've been looking at a VW/ Westfalia setup that is very light.
    Gosh! Seems like there are quite a few of us looking at ordering a Finch shell soon! I'll probably order mine later this week or early next week and was going to go with just the factory furnace and 60" yakima tracks options (been on the fence on whether to get the screen door) - now I'm questioning the factory furnace!
    Thanks Overland Hadley for the thread and mtndog for getting us all geeked about a Finch on our 2005+ Tacos!
    -joe D.
  3. #53
    Join Date
    Mar 2007
    Location
    Marquette, Michigan
    Posts
    975
    My vote would be yes for the furnace. If you are going to camp in early spring or late fall you will really like it. Especially where you live. I have a Mr. Buddy and have used it with my old Fleetwood Neon. It's a nice heater but my biggest complaint is that it doesn't have a thermostat. You will be either cooking or freezing. Although I have never read a single report (I've searched) about any deaths related to a catalitic heaters, it has always made me a little nervous. I like the fact that my forced air furnace is vented. As mentioned you will have to have enough battery power to run it. The new furnace that FWC is using uses less amps then the one I have.
    You could always make up your mind later and put one in yourself.
  4. #54
    Join Date
    Sep 2007
    Location
    Central Nowhere
    Posts
    3,685
    Thanks everybody for the replies about the heater. I will figure out a different option for the heater.
    Tacoma - For Extended Overland Travels
    2012 FWC - The FWC Build
    Trip Reports - Travels with Hadley
    -Nathanael
    Large Format Photography
    www.KuenzliPhotography.com
  5. #55
    Join Date
    Sep 2007
    Location
    Central Nowhere
    Posts
    3,685
    Quote Originally Posted by Northern Explorer View Post
    My vote would be yes for the furnace....
    I want to have very minimal battery in my camper. Just enough to run a laptop.
    And a heater that needs battery power is not ideal, as batteries do not do that well in cold weather.
    -Nathanael
  6. #56
    Join Date
    Sep 2007
    Location
    Central Nowhere
    Posts
    3,685
    Working on it.
    I have a portable stove as I like to cook outside as much as possible. And I have a very nice sink that I will be installing in the camper, will make a post about it soon.
    Do you have a link to the Westy setup?
    -Nathanael
  7. #57
    Join Date
    Mar 2007
    Location
    Marquette, Michigan
    Posts
    975
    Here is an option for you. The only thing I know about them is what's stated on their web site.
    Catalitic
    Vented
    Low amp draw
    Thermostate
    All looks good but I can't find the price. Platinum Cat heaters
  8. #58
    Join Date
    Sep 2007
    Location
    Central Nowhere
    Posts
    3,685
    Quote Originally Posted by mtndog View Post
    I'll chime in, I have a Finch shell with factory heater, in fact, the silver taco pics in the original post is mine from the day I brought it home. After nearly 3 years use, I have never used the heater, but I do run an extension hose from propane tank to my stove outside the camper. If I ordered again, I wouldn't order the heater. I would use a little buddy if needed and carry a small 4lb or 11lb propane tank for my cooking and shower duties. In addition, if you run the heater, you will need to design/install enough battery power to run the fan however long you have it on. YMMV.
    By the way, a Finch shell with full propane tank is 525lbs.
    mtndog,
    Thank you for the information. Good to know the exact weight. And thank you for being one of the first to put a Finch on a Gen 2 Tacoma.
    Any first hand advice for those of us wanting to put a Finch on our Tacoma? Do you still have the tailgate on?
    -Nathanael
  9. #59
    Join Date
    Sep 2007
    Location
    Central Nowhere
    Posts
    3,685
    Catalitic
    Vented
    Low amp draw
    Thermostate
    Looks promising. Got it bookmarked and will do further research on it. Thanks!
    Edit: Emailed them to get pricing information. I will update this post when I get a price quote.
    Price is $450 plus shipping.
    -Nathanael
  10. #60
    Join Date
    Oct 2005
    Location
    Washington
    Posts
    13
    Quote Originally Posted by Overland Hadley View Post
    mtndog,
    I removed the tailgate after my first trip. It is too hard to exit, you really need to step down out of the door to exit comfortably. I fab'd up a dual-swing gate in place of the tailgate....it holds extra gas, water, hi-jack, and tools in an ammo can.
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
