Page 4 of 5 FirstFirst ... 2345 LastLast
Thread: Shipping Container camper...
  1. #31
    Join Date
    Jun 2008
    Location
    on the road
    Posts
    512
    For as cheap as you could buy a dolly-set, I can't see how you could go wrong. Even if you only ended up using the axles and some bits and pieces of it. But personally, I don't think I'll spend much time trying to improve on it. Looks pretty straightforward to me, and yes, from what I understand, the front axle is on a pivot and functions sort of like a 5th wheel dolly. They use standard deuce wheels/tires (40-43" tall), so the ground clearance can't be too bad, and the load-height looks pretty good too. All in all, a much better solution for me than buying a lowboy trailer. Mostly because I can buy a dolly-set and several shipping containers for what a trailer would cost me.
  2. #32
    Join Date
    Jun 2009
    Location
    currently, Vilseck Germany
    Posts
    1,347
    Default Need more intel...
    Do you know anyone that knows anything about these in detail? How they work, some kind of online resource? I real curious now...gee, thanks! Haha.
    Only flaw I see for my application is the air brakes. I have no way to run them of a civvy 3/4 ton truck...? Thoughts?
  3. #33
    Join Date
    Jun 2008
    Location
    on the road
    Posts
    512
    Quote Originally Posted by jeepdreamer View Post
    Yes, search the forums on steelsoldiers. I'm going to replace the air-assisted brakes on Mah Deuce with hydraulically-assisted brakes, so I'll have a similar problem. Haven't looked into it in detail yet, but I don't think it's a very difficult problem to solve. That is, as long as your truck/trailer has an air compressor onboard. Having the brake pedal/linkage activate an air-switch doesn't seem much different than activating an electrical switch.
  4. #34
    Join Date
    Jun 2009
    Location
    Posts
    1,347
    Default Can't register...
    JG, I tried to register on SS site but it says registration is closed for new site something-or-other..? I found a couple posts on the forum that talks about the dollies but I have no way to pm the folks? You ever talk to ARMYMAN30YearsPlus ?? He seems to have several of them (one of each size!) and may have some good intel. I'd like to know more but can't get hold of him...Thoughts?
  5. #35
    Default Mobile Condo
    Is this what you were looking for?
    http://mobilecondo.blogspot.com/
  6. #36
    Default What about a Garbage Container?
    Used to work as a garbage man some time ago... back then I wasn't hooked on off-roading as I am now, but now I think about a roll off dumpster/garbage container and how it could be modified to be a living container. Further, it could be dropped and you could still use the truck to get around...
    Something to consider. I don't have the money to even entertain the idea - and if I built it, I'd be living in it and single... but someone else with the $$ or a supportive wife could do it...
    just an option..
    Bryan
  7. #37
    Join Date
    Nov 2010
    Location
    Mainz / Germany
    Posts
    5
    Hello together,
    search here someone for a truck pickup system. We can build it or we can sell the complete system.
    www.xterra-mobil.de
  8. #38
    Join Date
    Jan 2010
    Location
    Canada
    Posts
    455
    Quote Originally Posted by sufisch View Post
    Hello together,
    www.xterra-mobil.de
    Nice concept!
    [ame="http://www.youtube.com/watch?v=mY1toD0tHQ8&feature=player_embedded"]YouTube - XTerra Mobil[/ame]
  9. #39
    Join Date
    Nov 2010
    Location
    Mainz / Germany
    Posts
    5
    Here are a another video. It is our prototype for living on the ground level, you dont have all the steps ... and you can seperate it from the truck.
  10. #40
    Join Date
    Nov 2010
    Location
    Mainz / Germany
    Posts
    5
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
