O3 Tundra limited with ATTITUDE,fire truck air horn,extream outback compressor,Ham radios,Motorola commerical VHF,UHF, lowband,800mgz radios with 100 watt pa system.Dual battries, ,KC daylighters,rock lights,RCD 6" lift,air chucks front and rear,tow truck jumper cables front and rear.CB radio for trail comm.Paramedic truma first aid kit,fire supression kit.09 horizon trailer,Warn 9000 winch. Helton heat exchanger,Lowrance chart plotter,David Clark head set for radios. KI6IGN
The Rhino looks really great!
I have been meaning to do something similar for a while. I'm curious which product you went with? "Extreme" seems like the best choice after some very cursory research. Have you tested the durability on the sliders at all? What is your plan for touch ups? How much of the frame did you do? What sort of prep?
Sorry for so many questions, I'm asking because I get the feeling from your build thread that you thought all this out before doing it.
Anywhere I roam where I lay my head is home.... Metallica, the black album.
www.northwestoverlandsociety.org
The truck is sprayed with Rhino Liner HardLine: http://liners.rhinolinings.com/en/products/hardline
My decision was based on a few factors, cost obviously a top concern but I also wanted something that could be easily touched up at the dealer. For the sliders my main issue was corrosion proofing, painting them each year was a PITA. If/when they get scratched or gouged I'll touch up the wound with Rust Oleum semi-gloss black, I just wanted 99% of those suckers rust proofed. The frame is coated all along from the front cab mount to the rear wheel well.
I learned a few things along the way like the fact that the UV topcoat needs to be re-sprayed every so often, the Solar Max coating is crazy $$$ like about 10 times as much as HardLine. And you can basically refresh the appearance of HardLine or any of their products with Rhino Shine as needed so spending 10 times as much for the same functional effect was just silly IMO. All of this advice was given to me by the owner who has been a Rhino dealer for over 10 years and knows the product very well, Rhino is based in San Diego BTW so anyone in SoCal may consider that factor as it was important to me to support a local company.
Dave are you going to make it up to the Wa Overland rally again this year? Id like to get a closer look at your truck again.
Dave, too bad you're not able to come back up here for the WA Expo. It was fun meeting you last year. I was the old fart on the '02 BMW Dakar.
When I built up my 2000 Tacoma Xcab I picked up a pair of sliders very similar to yours from a fellow named AJ in Sacremento. Prior to welding them on the frame, I had them Linexed. I really liked the looks and the coating gave a good grip to the soles of ones' shoes when entering/exiting the cab. While doing the Lockard Basin Trail in Moab a couple years later I had the misfortune of sliding along an outcropping boulder. The Linex pealed off the tubing of the slider like a knife cutting through butter. I was amazed, but looking back at it now should have realized that would happen. So for those thinking about doing a Linex or Rhino type lining, just remember that this stuff is great for corrosion proofing, takes lots of heavy duty wear, but is not abrasion proof.
I never get tired of looking at this truck. Thanks for the inspiration Tacodoc!![]()
