Thread: Doc's 05 Tacoma Build Thread
  1. #1791
    Join Date
    Jul 2011
    Location
    Seattle
    Posts
    490
    It would be stellar to figure out a way to mount a LPG container under the rear quarter fender - there is some wasted space up under there.
    I like how the fender wrap on the bumper sticks out far enough to be used as a step.
    Curiously, what gauge material are they using on that?
    Strong work, looking forward to some more "bigger pictures".
    This post was most likely made from my Tmobile Droid so spelling and punctuation errors are expected.
    2007 Toyota Tacoma DC 6spd. 4WD TRD - http://www.expeditionportal.com/foru...rk-In-Progress
  2. #1792
    Join Date
    Dec 2005
    Location
    Temecula Valley
    Posts
    9,762
    Quote Originally Posted by barlowrs View Post
    Propane mount under the bumper?
    Nope, it will be on the swingout. That's just the regulator and line hanging down waiting for tabs. The line will run to the tank from the hard mounted (protected) regulator under there.
    Dave Bennett, Member #203
    Travel, Explore, Live: AMERICAN ADVENTURIST
  3. #1793
    Join Date
    Apr 2007
    Location
    Orange County, Ca
    Posts
    1,060
    ahhh ok makes sense. I like. Hurry up and get her done so you can actually get back out somewhere with us haha
    Robert
    KG6BRB (Radio Installed finally, now trying to learn to use it)
    2006 Tacoma Access Cab (SLOW build thread: http://www.expeditionportal.com/foru...ad.php?t=36561)
  4. #1794
    Knowing Doc, it is probably a flamethrower......
    Jim
    4x4 Tourist
    Trip reports are on my Blog: "Sun To The North"
    Two Favorite Expo Quotes: "A bad day on the trail is better than a good day in the city" & "Bad days make for GREAT stories!"
  5. #1795
    Join Date
    Dec 2005
    Location
    Temecula Valley
    Posts
    9,762
    Lightbulb More progress, more pics
    Looks like the swingout will be going on next week and then all the finer details will be added and then off for powder coat... stay tuned
  6. #1796
    Join Date
    Dec 2005
    Location
    Temecula Valley
    Posts
    9,762
    Default More progress...
    Getting the swingout dialed in. This configuration allows for 2 or 4 cans (your choice) as well as propane, pioneer tools and Hi-Lift. Stout, traditional tow hitch as well as recovery points and Hi-Lift jack friendly. An optional spare tire mount can be attached in the center as well (2 spares anyone?)
    Next up will be a receiver on the swingout for attaching a Thule or Yakima bike rack, LED rear back up/camp light and fold down aluminum table.
    Bumper requirements:
    1. OEM quality tow hitch
    2. Trailer wiring plug provision
    3. Recovery points x2
    4. Hi-Lift jack points x2
    5. Thule/Yakima bike rack compatible with hitch attached to swingout
    6. 4WD Mud flap attachment
    7. Provision for 2 LED rock light pods at corners
    Swingout requirements:
    1. 2 AT aluminum can carriers
    2. Aluminess shovel/axe mount
    3. AT aluminum propane bracket
    4. Flip down aluminum table
    5. LED back up light mounted center on stalk
    6. Provision for propane hose and wire harness flex at hinge
    7. Lockability. Locks closed and open.
  7. #1797
    Wow.... you have been thinking this one through!
    Just trying out a new 12 series IP address :-)
    Jim
    4x4 Tourist
  8. #1798
    Join Date
    Apr 2011
    Location
    Los Angeles, Ca.
    Posts
    350
  9. #1799
    Join Date
    Jul 2011
    Location
    Oregon
    Posts
    141
    Looking very nice. Yea moving the spare back under the truck just makes sense. I just did the same. Better CG location, keep cg low and closer to the axle, got rid of some of the unnecessary rock and roll. I suppose one could do a skid that pulls up with the spare tire, more for tire protection not really to skid on. Now you have room for more gear (weight) on swing out. I like it!
    Cam-shaft.
  10. #1800
    Join Date
    Nov 2008
    Location
    Oceanside Ca.
    Posts
    1,501
    Looks great Dave, I am concerned, only question is you have mounts for the fuel cans ect. I see no mounts for the Snow Peak equipment!!!
    O3 Tundra limited with ATTITUDE,fire truck air horn,extream outback compressor,Ham radios,Motorola commerical VHF,UHF, lowband,800mgz radios with 100 watt pa system.Dual battries, ,KC daylighters,rock lights,RCD 6" lift,air chucks front and rear,tow truck jumper cables front and rear.CB radio for trail comm.Paramedic truma first aid kit,fire supression kit.09 horizon trailer,Warn 9000 winch. Helton heat exchanger,Lowrance chart plotter,David Clark head set for radios. KI6IGN
Page 180 of 192 FirstFirst ... 80130170178179180181182190 ... LastLast
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
