Thread: Front axel bearing unit question
  1. #1
    Join Date
    Oct 2010
    Location
    colorado
    Posts
    44
    Default Front axel bearing unit question
    Any idea how long a Ford front hub bearing unit will last with normal use??? It is in a 2003 E350 w/7.3 power stroke Quigley van Dana 60. Anbody have any idea they do a bearing unit instead of the old way? It is about 1000.00 in parts WTF!!!!!!
  2. #2
    Join Date
    Jan 2007
    Location
    AVL, NC
    Posts
    3,117
    Under normal use, you should see at least 100K from a unit bearing. Depending on the brand, the replacement price should be $3-400 each.
    Chris Steuber
    02 E350 7.3 V4
    11 E350 5.4 V5
    99 E36 M3 (LS swap coming soon)
    www.ujointoffroad.com
    4x4 Van Conversions
  3. #3
    Join Date
    Jan 2009
    Location
    Drake Co
    Posts
    480
    I would say 100k if you are running stock tires and not wheeling it or towing alot with it. If you are 50 to 60 k is about all you will get out of them. You can by a kit to run conventional bearings in that axle it runs about a grand but worth it if you ask me.
    Derek
  4. #4
    Join Date
    Oct 2010
    Location
    colorado
    Posts
    44
    Who makes the kit? What are the signs when they do start to go bad? Do you have some warning ? If so how many miles approximately? The unit bearing has got to be one of Fords lamest ideas. And I do know there are lots of manufacturers that use them in cars. But in a 4x4 WTF!!!
  5. #5
    Join Date
    Jan 2007
    Location
    AVL, NC
    Posts
    3,117
    More like $1989.
    http://www.dynatrac.com/products_freespin_ford.html
    Tire size & height, wheel backspacing, and load all affect the life of these bearings.
    Chris Steuber
    02 E350 7.3 V4
    11 E350 5.4 V5
    4x4 Van Conversions
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
