Page 1 of 4 123 ... LastLast
Thread: Wiper fluid froze. Solutions?
  1. #1
    Join Date
    Dec 2007
    Location
    Salt Lake
    Posts
    1,199
    Default Wiper fluid froze. Solutions?
    In the 12 years I've been traveling in the 0 to -20 temps, I don't recall the wiper fluid freezing up on me. It happened last week in Wyoming when it was about 6 degrees out. Traveled from Utah in above freezing temps and a couple of hours later when I hit the wiper fluid button, nothing happened. I thought I'd run out, so got some more, but there was plenty in there. I'm assuming the fluid froze, as it works fine now.
    Never had this happen before in any of my trucks/cars. But to keep this a one-time deal, are there any preventative measures or solutions?
    •UZJ100 •
  2. #2
    Join Date
    Aug 2008
    Location
    Cypress, TX
    Posts
    613
    There are quite a few types of windshield washer fluid with anti-freeze added to them. Most have either methanol or ethanol added to them to lower the freezing temperature. Depending on the temperatures you'll be in, I'd think those would work fairly well.
    There are also several manufacturers of kits that heat your windshield wiper fluid lines to prevent freezing of the liquid. I seem to remember seeing a write-up (here on ExPo maybe?) of someone that installed a kit that actually heated the entire wiper arm and fluid lines. From what I remember it was a fairly involved install. Not sure how effective any of those options are though.
    Electric heater - http://www.windshieldwiperheaters.com/index.htm, [ame="http://www.amazon.com/AlphaTherm-AT-38OD-Windshield-Washer-Heater/dp/B0034GW1WW"]Amazon.com: AlphaTherm AT-38OD Windshield Washer Fluid Heater: Automotive[/ame]
    Heated pads that stick to the windshield and heat the wipers while they're 'parked' - http://www.mirrorliteco.com/northwind.html
    I'd say that if you'll only occasionally see those types of temperatures, just buy an anti-freeze type fluid and be done with it.
    Ryan
    2008 Tacoma
    1968 Camaro
    "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them" - Thomas Jefferson
    "We all dream of a world filled with sunshine, peace, and happiness. The problem is that half the people think this sounds like a wonderful place to live...while the other half think it sounds like a wonderful place to pillage."
  3. #3
    Join Date
    Sep 2010
    Location
    Yankton, SD
    Posts
    332
    Sounds like you had a weak mixture of alchohol in your windshield washer fluid.
    For the winter I prefer the kind with the De-icer built in. I if you buy the "better" brands theystate at what temp they will freeze. Most are good down to -30 deg f ish range.
  4. #4
    Join Date
    Jun 2008
    Location
    Currently: Fairbanks,Ak
    Posts
    476
    Adding alcohol to the solution would be a good idea. But the freezing may be occurring at the spray nozzles on the outside of the vehicle.
    "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them." Thomas Jefferson
    2007 Tundra Crewmax 5.7L 4x4 (with a lot of miles)
    Northstar TC650 slide-in
  5. #5
    Join Date
    May 2008
    Location
    central wv
    Posts
    679
    happened to me last year in my 08 tacoma. went to the drug store and bought some alcohol and dumped it in after breaking up the washer fluid in the resevoir. worked pretty good. i did notice a smell in the cab at times, though. not over bearing, but noticeable. i would hit the washer fluid every now and again to try to keep some alcohol in the lines. i think it's worth buying the winter time washer fluid after last year.
    2004 toyota sequoia, to keep the wife happy
    2000 chevy tahoe NBS, 5.3, keys & spacers, bilstein 5100's, 285 AT's
    1989 4-runner; 3" BL, 255/85 bighorns on '09 taco steelies, 5.29's, rear spool, cobra 25, hella 500's w/more to come
    1995 geo tracker, leveled, 31" GY MTR's, no top.
  6. #6
    Join Date
    Oct 2009
    Location
    flat earth Midwest
    Posts
    197
    Prestone makes a Deicer Windshield Washer Fluid. Rain-X (or one of the other windshield treatments that) also makes washer fluids under its brand has a special deicer formula also. I've used both with great success.
    Keep in mind that products like this tend to be regional. If you're traveling and run into such weather, needing some, head for a local supply house and you can usually find it -- unless the locals have already bought the supply up.
    1997 FZJ80 The Sacred Cow 152k, 255/85 R16 BFG KM2 on 16x8 Toyota Steels Rims, ARB w/ XRC12, dual batteries/Hellroaring isolator w/ Blue Sea battery switch feeding winch and dual inverters, CDL switch w/ 7-pin mod, cupholders!, 8-ton pintle hitch w/ GI chain plate, blue-PHH, working power antenna, FSM, camper conversion
    M101 CDN Tagalong to the boonies, 255/85 BFG KM2 on 16x8 Alloys, w/ custom extra wide fenders, fresh OD paint, bungied tarp and bows
  7. #7
    Join Date
    Aug 2010
    Location
    Seattle,Wa
    Posts
    132
    Wurth windshield additive gets my vote. I'm lucky enough to have Wurth products stocked at my local import store.
    http://www.autogeek.net/w892332836.html
    Wurth also makes a nice product that helps against the door seals freezing/sticking against the car, and can be found in either a spray or wipe on application.
    My word of advice would be to install whichever additive product you choose and cycle some through until you know the additive is in all of the smaller supply lines.
  8. #8
    Join Date
    Dec 2009
    Location
    Brooklyn NY
    Posts
    889
    Add a alcohol 90% ethanol from any local pharmacy and a little amount of shampoo
    Or vodka Gordon other cheap solution $ 13 for 1/2 a gallon http://alcoholshopper.com/tables.php?offset=4257&max=9507&sort=name&order=as c&cat=Liquor&table=all
  9. #9
    Join Date
    Nov 2009
    Location
    Missouri Ozarks Überland Basecamp
    Posts
    369
    Here is what I use, GUNK Windshield Cleaner. The product is concentrated, a 6oz. bottle makes 1-1/2 gallons. They also make the product with antifreeze added (Concentrated). You can easily store a bottle in your glove department. Good Stuff!
    "The farther one gets into the wilderness, the greater is the attraction of its lonely freedom" Theodore Roosevelt
    ORCC Off Road Camping Club - Explore The Ozarks Midwest Region
  10. #10
    Join Date
    Feb 2009
    Location
    Rocky Mountains, AB
    Posts
    81
    Theres heater elements that go in you're reservoir. Help on icy mornings and supposedly with mud too. Hot water is better for cleaning, well.... everything. Not too pricey either.
    If you're wiper fluid froze with the proper antifreeze, check your lines to see if theres anything exposed to wind (windchill on the highway) and insulate..... or use the Rain-X stuff.
    Milo
    '92 HDJ81
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
