Page 13 of 17 FirstFirst ... 31112131415 ... LastLast
Thread: In search of the "perfect" camper frame
  1. #121
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    Thanks guys.
    Lots of shinanigans to come soon...
    With nearly 300k miles on the ticker, the front end of this truck is screaming for money.
    but I refuse to spend any more on the TTB dana 50 front axle.
    I ran across a kingpin D60 that I couldnt pass up. Only catch is that it is still attached to the truck
    So this truck is getting a solid axle swap, regear, and more....
  2. #122
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    After enjoying some life, Im back at it....
    Done with the bed, and basically prepped for paint. 12+ hrs of wire wheel action
    Im currently fabricating under body boxes for it.... Once thats done, its time for paint, then new decking
  3. #123
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    And some more progress...
    After all fabrication was done it was taken down to the local self wash car wash and cleaned real well.
    New tie-down detail. There are 16 of these on this bed... cannot ever have enough!
    Then it was removed for the last time ( at least for now! ) to be prepped for paint.
    CAUGHT!! My wife poked her head in the shop right as I started... then I promptly told her to get the hell out! Hardener and thinner in paint is nasty stuff...
    And primed. Used one full QT. Finish paint will use considerably more to get good coverage.
    It went on really nice.
    more to come....
  4. #124
    Join Date
    Jun 2009
    Location
    UT
    Posts
    1,436
    Is that the primer, or the color choice? Because I like the color...
    "Do you know what a soldier is, young man? He's the chap who makes it possible for civilized folk to despise war." -Allan Massie
  5. #125
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    No way its staying THAT color!
    Thats the primer.... finish coats will be gloss black.
  6. #126
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    Like this!
    Now just for a couple of days to cure, reinstall, and install the decking!
  7. #127
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    Getting closer...
    Also installed a very simple and effective set of high lift jack mounts. Nothing more than 9/16 hardened bolts with some washers and spacers.... Acorn lug nuts hold the jack on.
  8. #128
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    Today I installed the tongue and groove decking. Oiled with a nice used motor oil/ATF/diesel mix.
  9. #129
    Join Date
    Jun 2009
    Location
    UT
    Posts
    1,436
    Bet that smells great!
  10. #130
    Join Date
    Sep 2009
    Location
    North Idaho
    Posts
    623
    Actually the paint still puts off more than the oiled boards. And you have to get your nose REAL close to smell the paint.
    The decking absorbs the oil in a matter of minutes, and protects it long term better than any off the shelf stain or sealer
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
