matt s
88 suburban. Trying to bring it back to life. 350 tbi. Sitting for 5 years. Ran tip top when parked.
Here's the deal. We got it running and it idles great and in neutral or park revs all the way up nice and smooth. Put it in drive and it can barely even go. It just doesn't make power or spool up. Sputters, coughs, backfires a little bit. Stinks like hell too. When it first started it wouldn't run well and shot a ton of crap out the exhaust. Big chunks of rusty garbage. I managed to get it up to 35 and drive it over to my parents place but that was it.
Bad Gas? Likely, however tank was mostly empty and we filled it and added a bit of heat (yeah I know heat is snake oil). That and the fact that it idles and revs great makes me think the gas is ok.
Fuel pump? I really don't want it to be this. Pain in the rear as it's an inner tank pump.
Fuel Filter? I just don't ever get that lucky. It's never that easy.
Plugged Cat? I am leaning towards this one. A cat that just sat there rusting away. There is a small exhaust leak right before the cat that drained a bunch of water out when we first started it. My flaw in that theory is that it revs in park. Does the engine produce less volume or pressure of exhaust without a load?
Tranny seems good
Not burning oil.
No obvious signs of head gasket or other similar issue.
No obvious vacuum leaks.
No check engine lights. (Thinking a bad sensor would have tripped this)
Since the burb is in Anchorage and I am in Wasilla (60 miles) I am really trying to narrow down the problem to the most likely culprit as it means I have to drive in to fix it on the weekend(s) without my normal set of tools or my nice warm work space.
That and I hate blindly chasing gremlins. :Mechanic:
Thanks in advance, let er rip.:victory:
Tranny seems good
Not burning oil.
