Code Monkey
So, I've been thinking about what systems would go where and what they would hook up to.
I want to use the vehicle in two modes - primarily with the camper attached, but from time to time I want to use just the flatbed. The 'garage' will always be there, but that leaves at least 5 to 8 feet of flatbed that is 8 feet wide behind it. The 'garage' can serve as a place to haul bikes or any other stuff I want to keep out of sight or inside a compartment to protect it from weather and road grime/etc., and that I don't want inside the camper (like gasoline, oil, etc., for the bikes/etc.).
Also, the 'garage' can serve as an ad-hoc sleeper when I am not hauling a bike or the camper.
So for the vehicle, with the 'garage' and the camper off, I would still like to have water, a genset to power things (charge batteries, run appliances in emergencies, etc.), and so on. The big heavy stuff like the primary large water tank, fuel, most (if not all) of the aux. batteries, will be on the vehicle whether the camper is attached or not.
Just about everybody needs heat, many people need or want A/C. Water, fuel, some way to cook food is nice. Lighting and so on. Also, I like backup systems, but I want to keep the weight down too so I won't have a backup system just for the unlikely chance that I might need to use it in some emergency.
Most campers, the Alaskan included, come with some of these systems. Usually a combination of propane, 12V powered stuff, and a hookup to 110/120V power and water when it is available.
I personally don't care for propane, so while I would maybe leave in the bottle (or a place to put the bottle) and maybe the plumbing for it, I would like to primarily use diesel powered appliances - especially for heating and cooking, which may be the major consumers of fuel? Not sure how much propane a fridge uses, but I have read good things about the Nova Kool 12V/110V fridges and freezers - that they don't take much power (I will have aux. batteries and solar power and a genset).
Keeping a small propane bottle and plumbing would maybe keep the resale value on the camper and allow me to have an external BBQ/range for get togethers, or as a backup for heat (catalytic heater) if something goes phooey with the diesel heat or it for any reason I need more heat than the primary heater can provide. So, I would have some propane and that would stick with the camper. The propane can also be a backup reserve for other people with their own campers who are traveling or staying in the same spot if we get stuck somewhere or don't want to head into town to fuel up just now, but need the propane.
Also, the systems that stay with the camper will give it some heat, water, etc. if I need to leave the camper at a campground while going somewhere with the truck (recovery vehicle, repairs, whatever).
The primary heat and cooking would be a diesel combo cooker/heater/hot water heater and maybe use another hot water heater element or two to keep the potable water and grey water from freezing in extremely colt temps. Maybe even plumb this into the coolant system of the engine to keep the engine warm so it will start easier in the morning. Again, this would be in the camper, but would have some hookups (hopefully quick disconnects) to the vehicle to get fuel (maybe a small 2 gal. diesel tank stays with the camper - these systems don't seem to use much fuel) and water and maybe the engine coolant system.
Water. The large water tank will be on the vehicle, but there will be a small water tank with the camper. The two will be plumbed together with the large tank feeding the small tank as necessary.
So, all the big tanks, the genset, most of the aux. batteries, are mounted down low and sturdily on the truck, the smaller reserve/feed tanks are kept in the camper, keeping the weight of the camper lighter, less complicated and yet minimally self-sufficient if/when it is separated from the truck. Maybe one or two aux. batteries in the camper for those appliances that need electricity to run and for minimal lighting - when mounted to the truck they would be tied into the larger set of aux. batteries mounted on the truck.
Not sure about the A/C - there would probably be one A/C unit on the camper (not on top) as venting the cold air from a remote A/C unit would probably be inefficient. The truck itself has A/C, but that would probably not feed into the garage and would require the engine to be running anyway. The garage will probably just have a 12V fan and LED lights and that would be about it.
