I sent mine back to Linear Logic for the upgrade:
http://www.scangauge.com/support/upgrade.shtml
This thing rocks! Easily user programmable for additional gauges.
Why do you have to program gauges? Differences and options available. You really don't want to scroll through a list of inactive gauges. It is better to add those that you want and can use.
I will admit to be somewhat intimidated by the instruction book. Finally I jumped in and it clicked.
You need to print out this file
Xgauge list of data to enter for vehicle specific gauges (PDF File) This gives you the line of information needed to add your choice of gauge.
I added a transmission temperature gauge as an example.
Adding transmission temperature to my truck:
Press the red circled home button first.
MORE>MORE>MORE>XGAUGE
Select the memory number for the new gauge. I chose 20 using the upper right button.
Next choose
EDIT (lower left)
This is where the information from the PDF chart is entered. The first input screen is
TXD
Use the left buttons to change the numeral or letter , up or down. The upper right button advances to the next digit. If you go too far or make a mistake just keep advancing and it will start again at the beginning.
Enter
6C10F122194001 and select
OK
RXF = 046205190640 , OK
RXD = 3008 , OK
MTH = 00090005FFD8 , OK
NAME = TFT , OK
SAVE
Done! Now you have transmission temperature available when you scroll through the list. It is only a couple degrees off of my other gauge while cold. It will be fun to closely compare
I also added horsepower.
Two thumbs up!
Hind sight being 20/20, if I was to invest in a transmission temperature gauge, this would be the only choice. The versatility and cost are very good. I can scan and clear a code on the road if needed. Monitor voltage and mileage. Any gauge I might want too.
Really a good value for the investment.
