Page 16 of 19 FirstFirst ... 61415161718 ... LastLast
Thread: I've left the Toyota Fold, AKA my Montero Build Thread
  1. #151
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    I forget the guy's name who was the caretaker when we were there. He has a built red wrangler if that rings any bells. We definently walked though that tunnel. It was a nice reprieve from the hot sun
    The kern river wasn't too impressive when we drove over it. We did hit up the kern river brewery the first day. Good tasty beer there. Pictures are trickling in from the crew so I'll look at t some later on and post the good ones.
  2. #152
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    Small but important mod today:
    Found some bolts to attach my new recovery point! I managed to increase my departure angle AND give myself to recover (or be recovered) from the rear. Thanks to scrubber3 for getting it to me.
    1999 4Runner Limited. Its green.
  3. #153
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    Here's a couple shots from my most recent trip up Sherman Pass and up to Monache Meadow up in the Sierras.
    There should be some sweet water crossing shots eventually, once the photographer uploads them...
  4. #154
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    Some more pictures of that last trip. I like the water crossing one the best
  5. #155
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    Now its time for a question. I used my truck for work the other day and I got check engine light and my rig started running like garbage. I made it to Kettleman City (awful place) and ended up being stuck there for almost 11 hours trying to get my truck diagnosed. There's no autozone to rent me a code reader there so I had to find a mechanic to do it for me. Turns out the code was for a misfire on cylinder 6. He pulled the spark plug to check compression and found this:
    Compression was fine but I'm pretty out of ideas how this happened. There wasn't any mark on the electrode like something hit it or anything, it was just pretty black. I'm not sure how a spark plug gets crushed without anything foreign in the cylinder. No weird noises from the engine when it happened and everything has been fine since that plug was replaced. Thoughts?
  6. #156
    Join Date
    Mar 2009
    Location
    Memphis, TN
    Posts
    240
    weird....quick question. Was there any carbon built up between the grounding strap and the electrode or is it mashed to the point that they are touching?
  7. #157
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    Quote Originally Posted by BlueBomber View Post
    They're touching and kinda melted together
  8. #158
    Join Date
    Jan 2007
    Location
    Denton, TX
    Posts
    4,252
    I'm thinking it wasn't gapped properly and finally built up enough carbon to cause the misfire. But that is purely speculative.
    Scott Brown- Overland Guide and Photographer
    1995 Montero SR--1987 4Runner(sold)--
    1997 Honda XR650L--1988 FJ62 Landcruiser (project)
    "You have to remain a bit naive, a bit risky, a bit crazy if you want to experience a real adventure. You have to push the limits."
  9. #159
    Join Date
    Mar 2009
    Location
    NorCal
    Posts
    3,288
    Glad to see you're making some progress there. Can I assume the original plugs are quality denso or ngk iridium plugs? If not, they will wear very very quickly and as you can tell they're far from easy to access.
    Quote Originally Posted by red87 View Post
    I bought a 'cheap' $60 actron obdii reader from pep boys.
    This is the same one on amazon.com (http://www.amazon.com/Actron-CP9125-.../dp/B0007LEG2K).
    I store it in the cubby hole for the bottle jack and have used it many times (mostly on other rigs) and IMHO it was well worth the $60.
    1989 SWB Montero (3.0L v6, rear LSD), 33" mudders
    1996 Montero SR (3.5L v6, rear Locker), 35" mudders, 3.15:1 xcase crawler gears
    Build Thread: http://www.expeditionportal.com/foru...su-build-up...
  10. #160
    Join Date
    Nov 2008
    Location
    Visalia, CA
    Posts
    425
    There isn't any carbon build up to speak of on the plug; the electrode is smashed together.
    The plugs were all densos but that stupid town I was stuck in didn't have any so cyl 6 now has a normal copper one. I had to get home somehow
    Good tip on that code reader, thanks. I may just pick one up. Either that or a scangauge so I can monitor the engine too.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
