Thread: Antenna mount grounding
  1. #1
    Default Antenna mount grounding
    I have a Yaesu 7800 right now and just use a magnetic NMO mount with a 1/4 wave antenna. I want to do something a little more permanent. I want to use a mirror-type mount and attach it to the side of my Yakima Load Warrior roof rack. I'm assuming that the mount won't have very good ground because the rack is mounted on the bars with rubber.
    Would using a ground strap attached from the mount to a screw that attaches the roof rack rails to the body of the Jeep work? Or is there a better way to do this?
  2. #2
    Keep in mind that a 2m ground plane needs to be 19" long. If you get good contact with the rack, there should be enough mass in the rack to offer a UHF/VHF plane. For added grounding a strap from the antenna mount to a rack mounting screw would also be a good option.
  3. #3
    Join Date
    Dec 2010
    Location
    Parker County TX & Santa Fe County NM
    Posts
    1,534
    If there are bolts that go through the rubber pads to mount the bars to the rack, you'll probably be OK but an extra ground strap never hurts either.
    As far as ground plane goes, you should be fine with your proximity to the roof, but if a 5/8-wave doesn't tune up well then try a 1/2-wave, they're much more forgiving of ground plane.
    '80 FJ40, '86 FJ60, '07 FJC
    N5MUD Parker County ARES/RACES
    4x4ham.com
    TLCA # 16550
  4. #4
    Ok thanks guys. I'll run a grounding strap to a mounting bolt just to be safe.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
