Page 4 of 4 FirstFirst ... 234
Thread: '97 GMC Safari AWD BackCountryVans maiden voyage
  1. #31
    Join Date
    Oct 2008
    Location
    Desert Hot Springs, CA
    Posts
    1,370
    So a couple general questions:
    Does the Safari grill just bolt right up to an Astro without changing the radiator support or anything else?
    Is there any benefit or reason to change the earlier 5 lug pattern to the 6 lug 03+ setup?
    Are the brakes and steering the same or were they upgraded when the 6 lug change was made? (Mine's a 96 with 5 lug)
    Terry
    1997 BMW R1100GS
    2000 EXCURSION 6.8 V10
    1994 F150 4.9 L6
    Age doesn’t always bring wisdom. Sometimes age comes alone.
  2. #32
    Join Date
    Jan 2009
    Location
    Elgin, IL (Chicago burb)
    Posts
    798
    Quote Originally Posted by RocKrawler View Post
    Direct swap 85-94 and 95-2005.
    Not really. GM switched them to 6 lugs cause they switched all half tons trucks to 6 lug. Making the swap would really be an unnecessary expense.
    Steering is the same, rear brakes changed to disk.
    Aaron
    1999 Astro (Green - Daily Driver) - 2WD, 4.3L, 3.23, 225k+ miles, FE2 steering
    1997 Astro (Grumpy - $250 Rally Van) - AWD, 4.3L, 3.42, 335k+ miles original engine, $30 eBay fuel pump, 2" lift, 31" tires, rear LSD
    2002 Jeep Liberty (Eugene - Her Jeep) - 4x4, 3.7L, 4.10, 4" lift, 32" tires, 195k+ miles, rear seat delete
    1980 Kawasaki KE100 (Bessie)
    My CarDomain
    Prev Astros:1997, 2000, 1994, 1987, 1986
  3. #33
    Join Date
    Oct 2008
    Location
    Posts
    1,370
    Quote Originally Posted by ihatemybike View Post
    Seems like it may be worth changing to get the rear disc upgrade alone!
    Terry
    1997 BMW R1100GS
    1994 F150 4.9 L6
  4. #34
    Join Date
    Jan 2009
    Location
    Posts
    798
    Not really, the fronts do most of the work anyway. Nobody has yet to perform the swap on the two main Astro/Safari forums. It's a lot of work and expense for not much gain.
    The main brake mods done on the 1985-2002 vans are 4x4 pickup calipers and pads in the front and Police package Caprice drums in the rear.
    Aaron
    My CarDomain
  5. #35
    Join Date
    Oct 2008
    Location
    Posts
    1,370
    The 4x4 pickup uses 6 lug though, and Caprice is 5 lug - so do they run different rims front & back?
    Terry
    1997 BMW R1100GS
    1994 F150 4.9 L6
  6. #36
    Join Date
    Jan 2009
    Location
    Posts
    798
    The older pickups are 5 lug, but we only use the caliper (bigger piston) and pads (more surface area). The stock Astro rotor is still used (same diameter). I've done this caliper upgrade on Green and it's quite a noticeable difference in stopping power.
    I've got an idea for a lo-buck rear disk swap, but I'm not going to post much about it till I get it to work.
    Aaron
    My CarDomain
  7. #37
    Join Date
    Oct 2008
    Location
    Posts
    1,370
    I'm going to start collecting the front parts - thats 95 Chevy 3/4 ton 2wd front calipers and pads right?
    Terry
    1997 BMW R1100GS
    1994 F150 4.9 L6
  8. #38
    Join Date
    Jun 2010
    Location
    Kamloops, BC, Canada
    Posts
    132
    The original poster purchased 98 1ton, single rear axle 4x4 truck calipers I believe...and I think the same is a 3/4ton heavy duty...other years probably apply.
    Waitin' on a couple bolts for the bumper support bracket here RK...tomorrow hopefully!
    Coming soon...backcountryvans.com
    -Serving the ASTRO & SAFARI Van
    -Solid UHMW Polyethylene Sub-frame spacers (body lift)
    -Steel Axle Spacers (lift blocks) with integrated Traction Bar (anti-spring wrap/wheel hop)
    -Bump Stop Spacers
    -Steel Off-Road Tubular Bumpers
  9. #39
    Join Date
    Oct 2008
    Location
    Posts
    1,370
    Quote Originally Posted by Loopie View Post
    Paypal ready when you are!
    Terry
    1997 BMW R1100GS
    1994 F150 4.9 L6
  10. #40
    Join Date
    Jan 2009
    Location
    Posts
    798
    Found my parts order when I did Green's front.
    A1-Cardone Brake Caliper-Front Part No 18-4122
    A1-Cardone Brake Caliper-Front Part No 18-4123
    Wagner Brake Pad Set Part No SX153
    After returning the cores, I did the job for less than $100.
    Aaron
    My CarDomain
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
