Thread: dual battery help
  1. #1
    Default dual battery help
    I think I have everything I need to get going but I just want a second opinion on my layout. Here is how I plan to wire everything, please let me know if I am doing something wrong or if there are any changes I should make before I get to deep into this project. Should I add a switch on the negative side of the relay to control when it links the batteries? The main use of the aux battery is just to run my fridge, I do not have a winch and I have no plans to get one again.
  2. #2
    Join Date
    Nov 2010
    Location
    Middle of Nowhere, Outer Skin of Space Ship Earth, 1 A.U. from Sol, Outskirts of Milky Way.
    Posts
    2,167
    Quote Originally Posted by thx138 View Post
    No, you don't fuse or switch a negative. If you added a switch, it would be on the positive side, never the negative.
    It looks good like it is. Good diagram of a basic split-charge relay. Simple and bulletproof.
    Current: 76 E-250, bubble-top, self-contained|couple of old Yamaha enduros
    Previous wheelers: 41 Willys|78 FJ40|78 Bronco|84 Bronco|74 Ramcharger|78 Ramcharger|79 D150 PowerWagon|77 D100|79 D400 dually, converted to 4WD, utility bed, 10' Lance|75 Westy|69 Scout, RHD|bunch of others|bunch of bikes|couple of boats|couple of motorhomes|blah blah|so what|not my idea|just doin' what I'm told|wank wank|this space for rent|candy is dandy|but liquor is quicker
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
