Hello everyone,
Sorry I haven't updated in a little bit, but I have been waiting for parts. In the mean time though, I was trying to figure out the floor mounting structure for the rear seats and drawer system; however, when I was stripping the interior out to look at the placement of that structure, I found a little moisture under the rear rubber mats (which is the dryer place in the Rover). So I immediately walked to the front and put my hand underneath the front rubber mats. Both the driver side and passenger side were wet underneath. The passenger side in particular though was sopping wet; it was like wringing out a car washing sponge (see pictures).
Keep in mind that I have already been through this once when first bought it. I stripped, primed, and repainted the whole floor because there was a small amount of surface rust on the floor. So you might be able to imagine my surprise/frustration to find that there was rust in the same places again. I decided this time I was going to make sure it would not happen again! The problems that caused were many, because to take care of it in a way that it would not happen again meant that I had to push my plans for the rest of the interior forward so it is going to be a very busy month for me. Added to the list besides the rear floor structure is now: the modified 95’ RRC steering column, modifying the dash, custom console, lowering the front seats, auxiliary fuse box, other misc. wiring, and sound insulation (Lizard Skin).
I am in the middle of the interior right now and have it completely stripped out. So figured I would show you a few in-progress pictures. As well as the pictures of where the leak was coming from. It turns out that the vent door foam was perished and was letting in a lot of water. If you are curious about your Rover, check under the front floor mats for signs of water, then pop out the outside vents on the cowl and you be able to see the vent door. I took it a step further and removed my cowl entirely to redo the seam sealer and check for rust. BEWARE! Removing the cowl is a careful two or even three man job, do not attempt it by yourself!
Anyway, there will be more work going on this week and I will try to update with pictures but in the mean time feel free to ask questions and I hope you all have a good one!
