Page 3 of 3 FirstFirst 123
Thread: 05+ Tacoma Dual Battery Location
  1. #21
    Join Date
    Jul 2011
    Location
    Maryland
    Posts
    759
    ^^ I like that set up. I dnt think they would both fit in my Tacoma side by side. I have plenty of room on the passenger fender. I thouht
    about puting the Air pump there.
  2. #22
    Quote Originally Posted by CLynn85 View Post
    So I've been planning on doing a dual batt setup for a while now. With the winch, aux in the cab, etc, but most importantly, the various camper setups, I figured it was time. I ordered up a warn isolator, but I'm having a hard time locating the second battery. I don't really want to do the dual setup in place of the big stocker, and I have ABS so there's not the nice spot on the passenger side that some others have used.
    I did, however, find that a group 51 would fit behind the fuse block in front of the brake master cyl if you relocate the relay box like so (ignore the crappy night-time cell phone pics):
    Attachment 67028
    Attachment 67029
    It will sit a little nicer if there was a tray, was cocked due to the curve of the inner fender.
    Has anyone tried this setup before? I know optima makes a yellow top in D51 configuration, are there any other deep cycles in this group size?
    I put a 2nd battery and aux fuse block in that position. It was easy to fabricate the mount for the battery. Some pics here: http://www.ttora.com/forum/showthread.php?t=67738
    CA4WDC #11593
    2006 Tacoma
    *****Don't believe everything you think*****
  3. #23
    Join Date
    Jul 2011
    Location
    Seattle
    Posts
    490
    Why add a second battery at all, why not get the BIGGEST battery that will fit in the stock position, add a three position bus block for the following:
    1)Exisitng Alternator connection
    2)Existing Factory fuse block connection
    3)New Aux fuse block connection
    On #3 (new Fuse block), include a low voltage cutoff switch between the fuse block and the bus block to maintain reserve starting power.
    I really dont see the need to having two batteries unless you really plan to run your battery down between charges. Having one bigger battery may be good enough for most uses. But, I am usually so tired I pass out by 7 PM so I dont need a lot of "late night ambience", for that I have a camp fire. Up early, to bed early. No need for lots of backup power.
    Need to watch TV or DVD? BLue-Ray is nice but a good book is better.
    Need to use that microwave? Eat it cold out of a can.
    Need to see in the dark? It's more challenging to fix it by feel.
    Just sayin.....this is where we cross the line from adventure to luxury.
    More breakable parts, more parts will break.
    The one thing we ALL need is cold beer.
  4. #24
    Join Date
    Apr 2009
    Location
    California Maritime Academy
    Posts
    117
    Quote Originally Posted by upcountry View Post
    SO true!
    Cadet 2/C Winter Wilson
    There is no one who more exemplifies the devotion to our country, its goodness, its industry, and its strength than John Wayne. ~ President Ronald Regan
  5. #25
    Join Date
    Jul 2011
    Location
    Oregon
    Posts
    141
    This is what I did. I did not like the idea of cramming two batt in front and adding extra weight to front corner of truck since taco allready leans to that side. Plus save weight for bumper and winch in front.
    Where are the batteries?
    Maybe there in that box?
    There they are.
    Cam-shaft.
  6. #26
    Join Date
    Jul 2011
    Location
    Maryland
    Posts
    759
    Nice battery box.^^Props to you..
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
