Thread: Cruiser electrical help for a friend.
  1. #1
    Join Date
    Aug 2006
    Location
    Groves Texas
    Posts
    169
    Default Cruiser electrical help for a friend.
    OK so here is the dumest question i have ever asked. My friends son lives in Boulder CO. He lives in Texas. His son has a 80 series Land Crusier. He replaced the raditor, and when he put the battrey back in he got the positive and the ground bassackwords. Could it have hurt any thing. I honestly could not tell him ether way sinc i have never made that mistake. He said it rained sprks and had fuses blown.
  2. #2
    Join Date
    Dec 2006
    Location
    Prescott, AZ, USA
    Posts
    4,002
    I have some unorthodox 12 volt electrical experience having owned a Series II Landrover with positive ground and converted it to negative ground.
    Connecting the battery up backward may have effected nothing more than the fuses. The relays would not have worked as no power would have gone to the switch side. If the 80 has a computer it may have fried it if it didn't have reverse polarity protection.
    I'd suggest;
    Replacing the blown fuses
    Visually inspecting the wiring harness for damage
    Reconnecting the battery correctly
    Starting the vehicle
    If it starts
    Check to make sure each of the circuits is functioning
    Check that the alternator is working
    If it doesn't start the computer may be fried.
    He can't do anymore damage than he may have already done by connecting it up correctly and seeing if it works.
  3. #3
    Join Date
    May 2006
    Location
    Gresham, Oregon
    Posts
    544
    Quote Originally Posted by texas taco
    There's several fusible links near the battery that probably went. Even if they look OK, they tend to be blown in a situation like this, so they'll probably need to be replaced. As far as any other damage, there's only one way to find out. Fortunately, the 80s have a few fuses bewteen the battery and computer. If it does run, good idea to check the wiring. Hopefully the fusible links right at the battery stopped any major damage though.
    Good luck. Hopefully it's OK>
    Brian McCamish
    In Search of History Expeditions
    Gresham, Oregon
    1995 Toyota Land Cruiser FZJ80 (new expedition rig)
    1989 Toyota 4x4 truck w/SAS (retired expedition rig)
    www.brian894x4.com (Homepage)
    Our Land Cruiser FZJ80 Main Page
    In Search of History Page
    Abandoned & Active Railroads of the NW Page
  4. #4
    Join Date
    Aug 2006
    Location
    Groves Texas
    Posts
    169
    Thanks for the replies. I realy appreciate all the info, oh and Brian you have an awesome web site.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
