Page 1 of 2 12 LastLast
Thread: Shower / hot water system
  1. #1
    Default Shower / hot water system
    Has anyone set a shower / hot water system up on a TJ? I know it's been done on some other vehicles, but I was wondering about TJ specific. Thank you in advance.
  2. #2
    Join Date
    Jan 2011
    Location
    CT
    Posts
    89
    Not really set up "in" my Jeep but I transport it in it...
    http://www.cabelas.com/product/Zodi-...cts&Ntt=shower
    Plus I can also use it for hot showers when I loose power in my house.
  3. #3
    Join Date
    Aug 2010
    Location
    Hampstead,NC
    Posts
    210
    X2. I believe there is a poll on here and zodi extreme seemed to be the most chosen by expo members...
  4. #4
    Default Thanks
    Jp90Talon and BEVAN thank you for your replies, but I'm looking for something permanent.
  5. #5
    One of the guys in Bay State Jeepers has a permanent setup in his LJ. He used a heat exchanger (not sure if it was a plate type or not) and a pump. He used a standard mixing valve setup for a utility sink (also mounted under the hood) that feeds a hose and showerhead. I'll see if I can find the pictures he posted of it during his build up.
  6. #6
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    6,180
    I've shipped out the Helton kits to dozens of Jeep owners, TJ's, JK's, XJ's, you name it. I've not installed one personally in a TJ but it can't be any more difficult than the other installs... hour or less.
    Kurt Williams
    Cruiser Outfitters
    Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
    Join us on Facebook
    ExpeditionUtah - A lifelong project of exploring Utah
    kurt@cruiseroutfitters.com
  7. #7
    Quote Originally Posted by Modeler View Post
    Looks like when the site was upgraded earlier this year the archives were not transferred over.
  8. #8
    Join Date
    Apr 2008
    Location
    Phoenix, AZ
    Posts
    964
    effeminately if you want a plug-n-play system go with the helton kit from cruiseroutfit - tried and true.
    if you want to source everything yourself, you may get some ideas from my install here: http://offroadpassport.com/forum/showthread.php?t=754
    i'm using a plate style heat exchanger, RV water pump, thermostatic mixer, and blah blah blah
    EDIT - the ORP site is up and down alot lately, we're upgrading hosts soon - for now if you can't get to above link, i have an overview here: http://www.expeditionportal.com/foru...717#post877717
  9. #9
    Default Thanks For The Info
    Thanks guys for the info. I'll take a look at the options, and maybe contacting about the Helton kit.
  10. #10
    Quote Originally Posted by theksmith View Post
    Great thread. One question---how cold will your anti-scald valve allow the water to get? If it will turn the hot side off altogether, you could probably get away with one output. Just something I am thinking of as I shamelessly steal your design.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
