Page 6 of 8 FirstFirst ... 45678 LastLast
Thread: Superduty V10 vs 6.0
  1. #51
    Quote Originally Posted by john101477 View Post
    The 6.0 was the biggest mistake of my life to date lol. 60,000 miles, 3 fuel injectors @ $1500 and $2000 for a high pressure oil pump. In 6 months!!!
    Never again
    I made the same mistake. I bought a 2005 ford excursion with the 6,0 in Denver Colorado for my wife, the check engine light came on 50 miles into Kansas. It barely made it to Pennsylvania. Took it to the dealer and found out it was the oil cooler. Bought the Bulletproof oil cooler kit and dealer installed it. 75 miles later, egr cooler and hpop went out. bought the Bulletproof egr cooler and dealer installed it and the hpop. $6000.00 later it runs, but I did some research and found out the 6.0 only has 10 head bolts holding each head on. My Chevy Tahoe has 18 on each side with half the compression. Needless to say, my 05 Excursion is up on ebay right now. It was the worst mistake of my life. With 10 head bolts per side, it's a matter of when, not if you blow a head gasket. $26000.00 into it, and I will be happy to get 11 or 12.
    http://cgi.ebay.com/ebaymotors/?cmd=...%3AMESELX%3AIT
  2. #52
    Join Date
    Jun 2011
    Location
    Southeast Tennessee
    Posts
    29
    I just bought my 05 F250 with a 6.0. I trust it in its stock state more than I ever trusted my Discovery. This truck isn't perfect but there was no amount of money that could be thrown at a Land Rover to make it dependable. I expect to have $2 - $3 grand in this truck tops on preventive upgrades. I had at least twice that amount in the LR and still lived in fear of it, and of course it cracked the block at 165K and was a total loss. Reliability is a matter of dedication, but you have to at least start with a foundation and I think the 6.0 is a solid foundation.
    "Saving the world was merely a hobby. My vocation has been that of
    inspector of desert water holes." --Edward Abbey
    2005 F250 Super Duty
  3. #53
    Join Date
    Jun 2008
    Location
    Long Island New York
    Posts
    180
    Quote Originally Posted by darien View Post
    I read yur post and I just have to respectfully disagree with the last sentence. The 6.0 is barely a solid foundation, there are serious design flaws with this engine that no amount of preventative or dedicated maintenance can overcome. I do wish you luck with your truck and I hope that it works out better than your Rover.
    2007 Rescue Green Wrangler Unlimited
    Outfitted for urban survival
  4. #54
    Join Date
    Sep 2011
    Location
    Murrieta, Ca
    Posts
    9
    I bought my '06 after doing research and am very happy with it. The '03-'05 were more problematic than the '06 and '07's in the F series and later 6.0 engines in the E series. The engine needs help to correct the common issues, but once taken care of they are good engines.
    Either delete the EGR or make sure the EGR isn't leaking and replace the EGR cooler with a Bulletproof diesel unit, replace the oil cooler while you are doing the EGR cooler because you're right there anyhow, flush out the Ford gold coolant and replaee with ELC coolant, and get a set of gauges to watch your essential data. Also, the 6.0 likes clean filters so routine maintenance and replacing oil filter, fuel filters, and air filter are important, but should be with any vehicle.
    Watch your ECT and EOT to make sure they are within 15 degrees of each other cruising at 65 mph. If they're not the EGR cooler / Oil cooler are probably plugged up. That's when you replace them with the above products. Other things to monitor are FICM, EGT, and Boost. It sounds like a lot, but I glance every now and then at a scanguage; not a big deal.
    Unless you're over boosting or running aggressive tunes your headgaskets will be fine. If you want to run a ton of power then swap out the torque to yield head bolts with ARP studs. A shop will have to lift the cab to do this, so it's pricey. If you're comfortable doing it yourself then a little firewall reshaping can get around the cab lift.
    Go to any make specific forum and you'll see all the horror stories and then do research and be proactive in maintenance of common problems .
    1989 4runner - 22RE 5spd adventure toy
    2006 F250 4x4 CC - Family hauler
    2000 XR650R - Go anywhere adventure bike
  5. #55
    Join Date
    Oct 2008
    Location
    Desert Hot Springs, CA
    Posts
    1,370
    I call poop on the last statement, people on a forum complaining about a $26 CPS on the 7.3 have too much time on their hands and can't figure out a 10mm wrench but have no problem with a computer. That's a lot different than the bucket of grief that is the 6.0 and its laundry list of expensive issues that need constant monitoring and repair. You also forgot to address the famous turbo issues the 6 litre is plauged with. Any vehicle that requires thousands of dollars yearly in mechanical maintenance is not a well designed initial platform, whig is why the ford 7.3 and cummins 5.9 have the reliable reputations they do, and the 6.0 does not.
    That same post in a 7.3 thread would say to keep a spare crank position sensor in the glove box and change your oil regularly.
    Sent from my ADR6400L using Tapatalk 2
    Terry
    1997 BMW R1100GS
    2000 EXCURSION 6.8 V10
    1994 F150 4.9 L6
    Age doesn’t always bring wisdom. Sometimes age comes alone.
  6. #56
    The 7.3 has 18 bolts holding the head on while the 6.0 only has 10. No amount of money in the world can fix that design flaw.
    95 solid axle tahoe
  7. #57
    Join Date
    Aug 2007
    Location
    Prescott Valley, AZ
    Posts
    1,252
    Quote Originally Posted by cmayer View Post
    This is a very true statement. I have a 2006 and love it. Even the guys on Bulletproof Powerstroke and lots of others say issues were pretty taken care of by the last 2 years' trucks, but the reputation had already been tarnished.
    If God is your co-pilot, switch seats!
    Brian Letendre, KE6IRJ
    http://www.ucora.org
    Our Family Blog
  8. #58
    Join Date
    Jul 2008
    Location
    On the move...
    Posts
    877
    Several months later and I'm no closer to a decision.
    V10 gasser: lower maintenance costs, higher gas bill, reliable engine but lacks tug boat abilities for a 2,000lb slide in camper and a 3,000lb Subaru behind it,
    6.0 diesel: narrowed my search to MY 2006, drives the price up a bit, RCD EGR delete kit drives the price up a lot, coil sprung front end opens up some nice suspension options, nagging doubt about reliability
    7.3 diesel: tough to find with relatively low mileage, go quicker than I can react, SFA makes suspension options really limited, 4 wheeling in Colorado a chore
    Aaargh.....
    Last edited by NothingClever; 08-18-2012 at 09:51 PM. Reason: Because I'm a Full-Size Noob, OK?
    Alright, this is just fancy car camping, people. Move along, move along.
  9. #59
    Join Date
    Nov 2009
    Location
    State College, PA
    Posts
    69
    Quote Originally Posted by NothingClever View Post
    As long as you have the right gearing/springs this loading should not be an issue for a V10 (3V or 2V). The diesels will accelerate a good bit better but the gas engine will still keep up with traffic well enough. The V10 was very popular with class A/B/C Motor Homes.
  10. #60
    Join Date
    May 2010
    Location
    Bowen Island BC
    Posts
    332
    V10 happiness is all about gearing. 4.30, 4.56, even 4.88 is where you can really take advantage of the v10's power.
    You mentioned IFS with the 6.0 . You must be referring to the coil springs upfront. None of the super duty 4x4's have IFS. All use solid axles, 99-04 leaf springs, 05-12 coil springs. Biggest advantage to the coil springs seems to be better turning radius and ease of lifting.
    Todd
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
