Thread: chaser trailer question's
  1. #1
    Default chaser trailer question's
    I'm thinking about taking the plunge and buying one this fall but I have a few questions about the trailer , hopefully someone can answer for me.
    I have all the dimensions on the site but I can't tell where the depth is measured. Say if you had the lid off what would the depth be to the top? Then what is the depth to the first bend? I'd like to use it without the lid at times.
    Also what is the track width?
    Thanks for the help!
  2. #2
    Join Date
    Dec 2006
    Location
    Prescott, AZ, USA
    Posts
    4,002
    Quote Originally Posted by detailbarn
    The main box is 26.28 inches top to bottom
    The lid is 6" deep
    Outside of fender to outside fender 64"
    Track width will vary with tire and rim selection, some fall a little outside the fender, some a little inside.
  3. #3
    martyn thanks for the info, do you think it will be ok to use the trailer with out the lid? I want to mount a rack system to the lip right before the slope in the side , how tall is that little side without the lid. thanks again for you help.
  4. #4
    Join Date
    Oct 2006
    Location
    Reno
    Posts
    2,136
    Unless you travel in low/no dust areas I would recommend trying to figure out a way to utilize the lid...
    1999 Toyota 100-Series Land Cruiser...not nearly stock
    2009 Kimberly Sports RV 'King of the Offroad' trailer: Sadly gone but it sponsored some of the best memories of anything I've ever owned!
  5. #5
    Join Date
    Dec 2006
    Location
    Prescott, AZ, USA
    Posts
    4,002
    No problem using it without the lid, we design the lid so all you have to do is remove the center hinge, undo the gas struts, and slide the lid off.
    The start of the first bend is 6" below the lip, 14" from the bottom of the box.
    Martyn
  6. #6
    Join Date
    Dec 2006
    Location
    Prescott, AZ, USA
    Posts
    4,002
    Quote Originally Posted by spressomon
    Good point. The track and rack system we use on the Chaser is made by Thule. So anything you wanted to add inside the box could be added to the lid.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
