Thread: Honda 2000 Generator Carry Solution.
  1. #1
    Join Date
    Aug 2009
    Location
    Central Kentucky
    Posts
    138
    Default Honda 2000 Generator Carry Solution.
    I recently purchased a new 2" hitch cargo carrier in order to carry my honda 2000 generator. I carry a Honda xr650L Dual Sport bike on the back of my Truck Camper so I needed to move the Honda Generator Box to the front hitch carrier.
    The Hitch Carrier was purchased from "eTrailer" and is for a 2" receiver and is an ATV model. It's rated for 150 pounds so it works well for the Honda 2000 generator at 53 pounds with fuel.
    The Generator fits into a 24 Gallon Action Packer, and the action packer is in a Baja Bin I bought from "Swag Off-Road." The Baja Bin is attached with locking nuts at the bottom to the carrier. Then the Baja Bin has 2 master locks. I know the entire set up is not theft proof, if someone wants it they can get it, but that goes for anything, I am just trying to make it more difficult to steal.
    Advantage of this type of carrier is that it sits higher than normal cargo carriers and will not hinder (too much) the take-off angle when ascending hills. Additionally you can see the top of the carrier from the drivers seat so you know how far it extends in front of the truck and it doesn't hinder the headlights.
    I posted so that others looking for hitch carrier ideas would see another option!
  2. #2
    Join Date
    Aug 2011
    Location
    Texas
    Posts
    146
    Be very careful with those crooked neck platform...I had one going down the highway one day, with only 55 pounds of gear on it...damn thing snapped and the only thing that kept it from completely tearing loose and causing and accident was a weld at the bottom. It was caused by all the bouncing up and down from the slack in the hitch. Now I use a FLAT platform on the front with straps holding up the platform with tension on it. One end is hooked on teh ends of the platform and the other end of the rachet strap it hooked under the hood. I also wrap electrical tape around the inserted part of the hitch shaft. Maeks it tight and the straps keep the whole thing from bouncing up and down. I'll be buying a Honda 3000i next summer before we hit the road...to run the AC in our popup camper while boondocking.
    JJ
  3. #3
    Join Date
    Aug 2009
    Location
    Central Kentucky
    Posts
    138
    If you notice in the pictures, I use two turnbuckles to prevent the carrier from bouncing and also have an anti-wobble device attached to where the carrier goes into the hitch. I'm confident it will work well, has so far, but thanks for the advice!
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
