Page 21 of 24 FirstFirst ... 111920212223 ... LastLast
Thread: Expedition Portal: The Land Rover 109 IIA Build
  1. #201
    MattScott's Avatar
    MattScott is offline Expedition Portal Team
    Expedition Portal Moderator
    Writing Enthusiast.
    Join Date
    Sep 2008
    Location
    Prescott, Arizona, United States
    Posts
    1,249
    Quote Originally Posted by greenmeanie View Post
    IIRC the genuine wires are carbon coated glass fiber. Good while they last but in the Phoenix heat rumbling upand down the I10 mine wouldn't last more than a year. I eventually just went with a set from Magnecor and never looked back.
    I think Magnecor likely makes a better product—but at $19 the Genuine wires will do.
    Matthew Scott
    Expedition Portal
    matthewscott.smugmug.com
    Land Rover TReK Extreme Vespa
  2. #202
    Join Date
    Jul 2008
    Location
    Georgia, USA
    Posts
    3,007
    Just an FYI, Kingsborne makes wires for the Series engines. I've been using them since the mid-80's when I used to sell them.
    Tom Rowe
    Four wheel drive allows you to get stuck
    in places even more inaccessible.
    62 88 reg
    67 NADA x2
    74 Air Portable - The Antichrist (tag 6A666)
    95 D1 5-speed
    95 D90 5-speed
    97 D1 Automatic
  3. #203
    Join Date
    Aug 2006
    Location
    Portsmouth NH
    Posts
    60
    Quote Originally Posted by Ray Hyland View Post
    Cool. I went to their booth at Sema and both the reps had never heard of Witworth tools. I guess I need to speak to a different rep.
    Ray
    quote from my Snap - on rep "whitworth.....ohhhh you mean British metric"
  4. #204
    Join Date
    Jul 2010
    Location
    Champaign, Illinois
    Posts
    1,641
    Side by side, I'd say the Kingsborne are the best wires and best value. . .
    David
    "The most unreliable car in the world is the most reliable car in the world." -Jeremy Clarkson
    "Adventure starts when everything goes wrong." -Yvon Chouinard
    1999 Discovery Series II "Oryx"
    1989 Range Rover Classic SWB "Addax"
    1992 Range Rover Classic SWB "Green Buffalo"
    1995 Discovery V8i "Crikey II" (Sold)
    1996 Discovery SD "Crikey I" (Sold)
    2001 Jaguar XJ8L Vanden Plas "Prince Harry"
  5. #205
    MattScott's Avatar
    Writing Enthusiast.
    Join Date
    Sep 2008
    Location
    Posts
    1,249
    Note to self: If your steering is incredibly vague, check the bolts on your steering box, I was missing one!
    Now she steers like a charm!
    Can't believe I missed that...
    Matthew Scott
    Expedition Portal
  6. #206
    If you are talking about the bolts that hold the steering box to the bulkhead support there are supposed to be lock tabs in there to help prevent this. Its common for them to be left off as its not the easiest place to get into to bend them into position. Part # 517878 if you should be needing them.
  7. #207
    Join Date
    Apr 2012
    Location
    Missoula, MT
    Posts
    35
    It's British you will always leak oil. Remember if it is bleeding it is alive. Had an old 72 Lightweight and it left plenty of reminders on my driveway.
  8. #208
    Join Date
    Apr 2009
    Location
    Bedford, UK
    Posts
    566
    Quote Originally Posted by CavTrooper View Post
    The gear box seats through the slector shaft seals, which collects and drips off the drain plug, and the o-ring on the 4wd selector pin weeps a tiny amount from the front of the 4wd housing, but if you have any other drips, then replacing the seals or any worn/corroded part the seal runs on will sort it out - my 109 only drips a couple of times a month from those transmission points but doesn't lose a drop anywhere else. My Lightweight has a slight weep from a fuel tank, so must have a perforated seam weld, and its noil cooler low pressure hose loses a drop one in a while, but that's it. Just like the reputation for sloppy steering and bad brakes, the reputation LRs have for leaks is due to age and poor maintenance by careless owners.
    It's not broken, it's British!
    www.nickslandrover.co.uk
  9. #209
    Join Date
    Jul 2010
    Location
    Champaign, Illinois
    Posts
    1,641
    I thrashed my 88 up and down from Phx to Tucson 5 days a week for over 100K miles . . .
    Now that's a Rover man. . .
  10. #210
    MattScott's Avatar
    Writing Enthusiast.
    Join Date
    Sep 2008
    Location
    Posts
    1,249
    Here's Ralph's latest adventure, now with added Russian supermodel!
    Matthew Scott
    Expedition Portal
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
