Page 6 of 7 FirstFirst ... 4567 LastLast
Thread: Your 2 cents please...
  1. #51
    Join Date
    Jun 2011
    Location
    Pennsylvania
    Posts
    2,035
    Thanks! Looks good and functional.
  2. #52
    Join Date
    Sep 2011
    Location
    98 XJ
    Posts
    53
    Default No pics tonight
    Made a mad dash home tonight after running late at work. Had just enough daylight left to use the tongue jack and rear stabilizers to lift the wheels off the ground. Hoped this would work for emergencies and had yet to test it.
    So the wheels came off and the replacement tires will get mounted and balanced tomorrow. Removed both hubs with bearings. These will get cleaned, inspected and either fresh grease or replaced. The stub axles look to be in good condition. The grease looked pretty fresh and clean, hopefully the bearings and races are good.
    Nothing going on tomorrow evening but there is a chance of rain. Weather permitting, we'll get back on the wheels tomorrow evening.
    Fenders and brackets are still waiting for paint. May not get back until Friday. Not to up tight about it as the weather is looking bleak for the weekend and the wife and I agreed the shakedown run will be done when the forecast is clear.
  3. #53
    Join Date
    Sep 2011
    Location
    98 XJ
    Posts
    53
    Default Moving along
    Down to the spindles . The bearings, races and axles all look in good condition. So I simply repacked them with grease and reassembled them. Had to replace one spindle cap as one was destroyed during removal.
    Next up was mounting the Kuhmo's that were bought to replace the weathered BFG's. Since the Jeep wheels on the trailer had the centers modified to fit the trailer spindles, I decided to give Equal a go for balancing the trailer tires. I'll post how it works after a few miles.
    Heres a pic of the fenders and brackets painted and ready to go. This is gonna wrap up the outside of this build other than somepaint work, wiring and some polishing on the hinge.
    More to come....
  4. #54
    Join Date
    Sep 2011
    Location
    98 XJ
    Posts
    53
    Default Fenders on
    Couple of days late on this update. The fender mount brackets and fenders have been installed. Take a look.
    The mount brackets are backed with a strip of rubber between them and the aluminum box.
    All stainless fasteners were used to keep things from rusting over time.
    The sides of the frame have been etch primed and painted now.
    So this concludes the majority of the big modifications. Wiring and plumbing still needs wrapped up. We had a major snow in our area yesterday and the temps are to moderate over the next couple of days. Should have some more posts for the weekend that will show the wrap-up. I am going to relocate the license plate to the back of the box and add a couple of LEDs for light under the lid.
    Hope to run the shake-down cruise soon. Will give a full report on how things work then.
    Enjoy!
  5. #55
    Join Date
    Dec 2008
    Location
    Beacon, NY
    Posts
    988
    Very nice job...congratz!!
    The New R.O.A.M. Camper Build...Recreation Optimized Allterrian Module
    Coming Soon.....R.O.A.M II
    Toyota 2010 4Runner Silver Trail Edition
  6. #56
    Join Date
    Jun 2011
    Location
    Pennsylvania
    Posts
    2,035
    The build looks Great! Keep us posted on any new add ons.
  7. #57
    Join Date
    Sep 2010
    Location
    here
    Posts
    39
    Have you had any problem with the trailer frame twisting? I have the same frame and wanted to build it up likewise, but was repeatedly advised that an angle iron frame would self destruct if used offroad.
  8. #58
    Join Date
    Sep 2011
    Location
    98 XJ
    Posts
    53
    Default Ready to get it wrapped up in the next day or so....
    Had to take a little break from the trailer to replace the cooling unit for the fridge in the MH. Not near as relaxing as the trailer build. But the fridge is about wrapped up now. So I expect to finally complete the trailer in the next week.
    oldboyscout, in severe conditions, the angle iron is nowhere near as strong as box steel or tubing (pending wall thickness, compostion,etc.) so if you are looking at heavy duty offroad use, build it strong. After the research that I have done and the people I have consulted, I believe that this trailer will suffice for our moderate offroad intentions.
    The Disclaimer: If we really enjoy the experience and the trailer does fold, then we will build our own frame. But only if necessary. I do not believe in overbuilding unless it is for EXTREME conditions. I like to build on a budget to fit the need.
    As for the promised update, EQUAL rocks. The new/used 35's were mounted on the last installment. We DID NOT ATTEMPT TO BALANCE the wheels and tires. Two 6oz bags of Equal per tire were added when we mounted the tires. The first 5 miles at 45-50 there was some wobble, then the bags self-destructed and everything smoothed right out. Amazing!!!
    Ran the Cherokee with the trailer out on the four lane for about 70 miles last Friday and it pulled straight and true. Had to drop the trailer tire pressure to about 14 psi to minimize bounce but the results are exciting. I just punched two vents in the hood of the Jeep today to allow heat to dissipate quicker for pulling the trailer.
    Some completion photos for next week!!!! Happy trails!!!!
  9. #59
    Join Date
    Feb 2012
    Location
    NW Arkansas
    Posts
    6
    I'm pretty new to Expedition style travel and have been reading thru your build. U used an angle iron trailer, which you said can tweak under hard use. Is it possible to weld a reinforcing strap and make it a "triangular frame"
  10. #60
    Join Date
    Sep 2011
    Location
    98 XJ
    Posts
    53
    Default Tested the grille...
    Still haven't done a full blown shake down trip, but we did use the trailer last evening for the camp fire in a can. It was a nice calm evening and we were hoping to see the moon as it was closer last night than it will be all year. The cloud cover was too heavy for the moon but we drained the LP tank hangin' at the camp fire.
    Today we broke in the grille doing veggies. The grille mount works great and there is plenty of clearance with the tent. Had some onion, pepper, portabela and fresh asparagus. Yum. Glad to report the grille is fully functional!
    Off topic but happy to report that the fridge in the motorhome is working great! Thats a project I hope won't need done again soon!
    Wiring is the final leg of the build and I hope to nail it this week.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
