Thread: New rig, help please!
  1. #1
    Join Date
    Nov 2010
    Location
    southern ga
    Posts
    143
    Default New rig, help please!
    Ok guys, ill post pics when i get home from school, picked up a k10 long bed gas auto truck on sunday, has 10 bolt front end and 10 bolt rear, well on the way to school this morning i felt a pop from the front end and stopped to see what it is, got out to find the driver side hub locked in and lose. it can turn about an inch both ways, so what do i do to get it home this afternoon? I have the tools to tear it apart if need be, the hub wont unlock.
    P.S. sorry for the bad grammar, Im in a rush for the teacher not to see
  2. #2
    Join Date
    Dec 2009
    Location
    Rifle, Colorado, United States
    Posts
    744
    does the tire/wheel still rotate? if so make sure the other hub is unlocked and drive it home. then tear it apart to see what broke.
    2000 ford excursion 33" cooper st maxx, diesel
    1994 ford explorer cooper stt's winch bumper, 8274
    1994 ford f350 crewcab powerstroke and five speed on 37's with superduty rsk and resevoir shocks
    1980 honda cb750 driveway holder downer
    my builds
    http://www.expeditionportal.com/foru...-expo-projects
    1988 fwc grandby
    http://www.expeditionportal.com/foru...the-fun-begins
  3. #3
    Join Date
    Nov 2010
    Location
    southern ga
    Posts
    143
    still drives fine, took the sector cap thing off and the grease smelled burnt, i think im just going to buy new hubs for both sides and be done with it, sooo, how much are hubs? I promise to post pics when i get home
  4. #4
    Join Date
    Feb 2011
    Location
    SW Va, USA
    Posts
    60
    If the grease smells burnt, it sounds like you need to have a look at your wheel bearings. After the lock out cap is off, take the internal snap ring out of the hub and pull the locking mechanism using two of the lock out cap bolts. Then you will have to have a hub nut socket to get the lock nuts off. Once the first nut is out, there is a ring that you have to use a pick to take out then another nut behind it. After that is out, pop the top of the rotor with you palm and the outter bearing will pop out. Put the inner hub nut back on and drag the rotor down the hub till you feel the inner bearing hit the nut. Slip it back a bit and pull very hard on the rotor outward so that the inner bearing and seal are popped out of the rotor. You can now clean everything and inspect them for damage. Remember, DO NOT PACK THE HUB FULL OF GREASE, only pack the bearings. The bearings only use the grease you pack into the rollers. All that open space in there is for cooling purposes, filling it full of grease causes the hub to hold much more heat and damage the bearings. I've been servicing wheel bearings since I was 12 and my Dad, who taught me, since the 60's.
    As for the lock out, a new set of Warn or Mile Markers isn't much, bout $50 I think.
    Terry
    1999 K1500 Suburban
    1984 K5 Blazer
    Wanna-be explorer living vicariously through the travels of others.
  5. #5
    Join Date
    Nov 2010
    Location
    southern ga
    Posts
    143
    Thank you so much for that info, im going to have to do that friday cause its my only day ome from school, so is it safe to drive back and fourth in this condition?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
