Page 1 of 2 12 LastLast
Thread: Best way to store a truck camper outside?
  1. #1
    Default Best way to store a truck camper outside?
    Any ideas or best practices on storing my truck camper when I'm not using it? Should I build a stand to sit it on? Recommended covers? Thanks Mike
  2. #2
    Join Date
    Jul 2007
    Location
    So Cal
    Posts
    1,738
    We have a 1999 Bigfoot C25 10.6, so it's a big camper. We set down 4 stacks of cinder blocks, one near each corner. Each stack is made from 3 blocks, 2 on the bottom, and then the 3rd block running crosswise to the other 2. We place a couple 2"x8" across the stacks, one across the front of the camper, and a second across the back. We set the camper down on that. We keep the jacks lowered touching the ground, but without having them carry much weight. That arrangement seems to work fine.
    We've tried various covers over the years. The Adco covers are OK, but the problem we have is they seldom last much past their warranty date. Seems like we can get about 2 years out of a cover, and they aren't particularly cheap. Over time we've become less and less picky about keeping it covered, so at this point we don't bother. The camper does look like it's been out in the sun, but not really too bad considering it's age.
  3. #3
    goodtimes's Avatar
    goodtimes is offline Expedition Portal Moderator Expedition Poseur
    Join Date
    Jul 2005
    Location
    Tucson
    Posts
    4,922
    I set my FWC down on what amounts to a stack of 4x4s - very similar to what cnynrat does. All the weight is on the wood, none on the jacks.
    I also don't cover mine - but it does get a couple of coats of Solar-tek roof coating when it starts getting thin.
    "Life is meant to be enjoyed, not endured" ~someone
  4. #4
    We store ours on pallets. Same deal no weight on the jacks really just use them for stability.
  5. #5
    Join Date
    May 2010
    Location
    Bowen Island BC
    Posts
    338
    I have two campers (don't ask) and store one of them on sawhorses and the other on 4 "blocks" made of cross stacked 2x4's. Both are covered with bungy'ed tarps when not in use. It rains A LOT here on the wet coast and I feel it's the best way to minimize leaks. I also usually leave one of the small windows open for airflow. Seems to help with mildew and mold (again very common here, even if you leave a car for a few months).
    Todd
  6. #6
    Join Date
    Oct 2008
    Location
    Whistler BC
    Posts
    2,001
    Where are you? The storage program is vastly different from Phoenix to Seattle to Telluride!
    As for stands, I like a set of folding aluminum saw horses like drywallers use. They are strong, won't rot, and are easy to store when the camper is on the truck. I also take mine with me when traveling on longer trips with the camper. They lay flat on the roof, and I can take the camper off to do some exploring at places where we stay for more than a few days.
    '98 Dodge 3500 CTD NV4500 complete with a crap load of goodies.
    '11 Rubicon Unlimited OME heavies
    '07 Adventurer 10T
    Sin niņo, tres perros y mucha tabletas de surf!
  7. #7
    Join Date
    Jul 2010
    Location
    On The Road
    Posts
    452
    I store mine (Big Foot 2500) on the 4 jacks and have done it for over 6 years now. Just wonder why others don't do the same ? Seems to work fine for me.
  8. #8
    Join Date
    Oct 2008
    Location
    Whistler BC
    Posts
    2,001
    Where I live we get 8' or more of snow, and besides that, campers are built to sit on the floor. Leaving them on the jacks alone puts all the weight on the few bolts in each corner. It is fine for short term, but I don't know of anyone other than you who leaves them on the jacks alone full time. I'm sure others do, but I've never seen it.
    '07 Adventurer 10T
  9. #9
    Join Date
    Dec 2009
    Location
    SE Alaska
    Posts
    182
    WE have a 1994 9.6 Northern Lite.
    Store outside on three of those yellow folding metal saw horses. The saw horses have 4 2x6s on them and a 1/2 piece of plywood so the bottom of the camper is completely supported. The 4 jacks have a cinder block under each on but little to no weight is on them only there for back up. then we wrap it in a large tarp and rope her down. The tarp will last usually two years and then fall apart from the UV damage. We keep it like that for about 3 months then it is back on the truck and ready to go.
  10. #10
    Join Date
    May 2010
    Location
    Huntsville, AL
    Posts
    206
    I bought a $400 canopy to protect our camper. Seemed like cheap insurance to keep it out of the constant weather. It stays on sawhorses to keep some of the load off the legs and make it more stable when I have to crawl in.
    06 Ram 3500 QC-LB, multi-purpose rig
    06 Starcraft Pine Mtn slide in pop up truck camper
    96 Jeep XJ 33's, long arm, trail rig and rock crawler
    76 Scout II, project in pieces
    09 Jeep JK Rubicon Unlimited (wife's ride)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
