Thread: P38 trans swap into D1??
  1. #1
    Join Date
    Jan 2010
    Location
    Victoria,BC Cananda
    Posts
    75
    Default P38 trans swap into D1??
    I found a P38 with low low KM on it. Would like to swap this trans into my 95 D1,is this possible?
    I know the p38 has the Borg waner t-case, so can I just swap out the output flanges??
    Looking for some to point me in the right direction.
    Thanks
  2. #2
    Join Date
    Jan 2009
    Location
    Auburn, CA
    Posts
    245
    Isnt the P38 ZF computer controlled like the D2 one?
    -Jeff
  3. #3
    Join Date
    Jan 2010
    Location
    Montreal,Quebec,Canada
    Posts
    119
    Cannot confirm but I heared that you can change the valve block from the disco and install,it on the p38 but the tcase is different
    94 Discovery
    " Stay Hungry Stay Foolish"
  4. #4
    Join Date
    Oct 2011
    Location
    florida
    Posts
    267
    I heard that , too. but after making a phone call , I was told that you have to exchange the governor , too
    Best would be to use a ZF22 body and bolt it to the ZF24 bell housing and turbo shaft assembly
    This Message is presented by Treasure coast Land Rover and Terrafirma serious 4x4 accesories
    1997 range rover 6.2L DSE
    engine HMMWV 6.2L diesel
    5 speed manual transmission
    HMMWV hydraulic winch
    4" lift
    toyota fj snorkel
    fierce attitude M/T on 16 inch rims
    matte black wrap
    https://www.youtube.com/watch?v=xKv0a9cUWp0
    1999 4.6L
    still stock
    2002 4.6L
    bone stock
    2002 parts car
    (contact me if you need something)
  5. #5
    Join Date
    Jan 2007
    Location
    Land between the Rivers
    Posts
    792
    Pardon me gents...but the P38 diffs are on the "wrong" side.
    Don't worry, you're biodegradable.
  6. #6
    Join Date
    Oct 2011
    Location
    florida
    Posts
    267
    You will have to use your LT230 to make it work
    4" lift
    toyota fj snorkel
    matte black wrap
    1999 4.6L
    still stock
    2002 4.6L
    bone stock
    2002 parts car
  7. #7
    I think the way it bolts to the Borg box is different then the d2 to the lt 230.
    For expedition tested Rover gear Check out WWW.Lucky8LLc.com 716-898-8153
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
