Thread: Shock failure experience
  1. #1
    Join Date
    Mar 2007
    Location
    Whittier, Ca
    Posts
    589
    Default Shock failure experience
    After my last trip out as usual, I filled up the SMB with fresh diesel so while stored there is as little space for any moisture condensation.
    A few days later while walking past the SMB I noticed a large puddle of diesel collecting on the ground. At first I just through it might be a fill hose loose but upon closer inspection here is what I found:
    It appears that the Bilstein shock stem broke away from it's upper mount and has been hammering one of the corner seams of my oversized fuel tank. The top weld seam must now have a small crack and is allowing fuel to escape.
    I've never had a shock mount stem shear off like this.
    What I thought was going to be an easy fix of tightening a hose clamp has now turned into a major job requireing the removal of the tank for repair.
    Anyone else had any experience with this type of problem?
    Thanks,
    Fred
    Explorer 1
    "Of all the paths you take in life,
    Make sure some of them are dirt"
  2. #2
    Join Date
    Dec 2010
    Location
    Bay Area, California
    Posts
    42
    For the fuel tank repair you could, since its at the top clean it up and use epoxy or some other type of metal repair, that way you don't have to take it out, plus it is really full now.
    As for the shock it looks like it broke where it was welded to the treads. I wonder if they are not long enough (too short when fully extended) for your application.
    Before you replace the shocks check carefully for the size you need do not just replace them with the same number.
  3. #3
    Join Date
    Mar 2007
    Location
    Whittier, Ca
    Posts
    589
    Default Outcome on shock.....
    I'll look into the epoxy idea, Thanks.
    I took the SMB back to Deavers who where the ones who installed the better leaf springs and Bilstein shocks. They took care of everything labor and parts FREE. It is so good to do business with someone who stands by their work.
    Thanks Jeff at Deavers,
    Fred
    Explorer 1 & 2
  4. #4
    Join Date
    Jan 2011
    Location
    Austin
    Posts
    2
    I was flying down the road leaving Scorpion Bay in Baja and hit a pot hole thus exploding a shock some years ago. It turns out Mortiqador is Spanish for shock. They fixed it for me in Ciudad Constitution.
  5. #5
    Join Date
    Feb 2011
    Location
    Spokane WA, USA
    Posts
    103
    FWIW I woudn't use epoxy for a permanent repair on something as critical as a fuel tank. Even if it's a PITA to remove, I am sure you would feel better 500 miles from home, in the middle of the desert, knowing that crack was fixed correctly..... rather than worrying that the epoxy might pop off and the crack could widen.
    Peace of mind is important!
    John Davies
    Spokane WA USA
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
