Page 3 of 3 FirstFirst 123
Thread: Parabolic Springs?
  1. #21
    Join Date
    Mar 2007
    Location
    The Nanny State
    Posts
    5,726
    Inter-leaf friction in leaf springs causes slow compliance and reduces the damper valving needed due to their own internal friction acting as a damping agent. Hum, sounds like the perfect pavement trailer spring - no dampers required if the internal friction is high enough compared to the spring rate.
    By reading TeriAnn's page I now understand what the differences btwn the "parabolic" leaves and std leaves are. The term "parabolic" may or may not be mis-applied. It would be pretty hard to visually see any difference btwn a parabolically arched leaf and a semi-elliptically arched spring. Which was a point of confusion for me.
    These "parabolic" features are also found in the late model 65" GM rear springs. These springs feature the leaf tip pads, which is not all that uncommon, but they also feature a shim/spacer btwn each leaf pair at the center pin that creates an air gap btwn the leaves. So the leaves only touch at the tips, considerably reducing the spring's internal friction. I have found that Bilstein's std leaf spring valve stack is not enough with these springs.
    I suspect that this lower overall damping value is what leads to complaints of instability etc.
    I think it would be an interesting experiment to install such shims in a "normal" spring pack and see what the vehicle's behavior differences are.
    I used to swerve around my hallucinations, now I drive right through them.
  2. #22
    Join Date
    Jan 2006
    Location
    pittsburgh
    Posts
    2,327
    ill be slappin a set of tic 4" paras on the fj 40 soon. ill keep yall posted.
    meh
    72 fj40, gone
    93 110NAS 238, gone
    71 fj55, gone
    86 fj60, gone
    76 fj40, polished up
    96 G, lotsa parts
    01 lx470, 150,000 dd
    97 f350/alaskan camper
    cars.
  3. #23
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    6,172
    As noted it is very interesting that parabolic spring experience vary greatly between the vehicles they are installed on. I know several Landcruiser owners that removed them shortly after install... for what they felt was an unstable and scary handling, poor load capacity, etc. Howevery, just about every old Rover guy I have talked to seems to swear by them.
    While parabolics reduce the spring to spring friction, its really neither here nor there as long as the friction is accounted for in the design of the spring (for a particular load capacity) and the matching dampner to go with it.
    Kurt Williams
    Cruiser Outfitters
    Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
    Join us on Facebook
    ExpeditionUtah - A lifelong project of exploring Utah
    kurt@cruiseroutfitters.com
  4. #24
    Join Date
    Dec 2006
    Location
    Prescott, AZ, USA
    Posts
    3,999
    Quote Originally Posted by cruiseroutfit
    Kurt, I'm not certain that parabolic springs reduce friction between the leaves. I think the use of the Teflon pads in this case achieves this. It's a little confusing on the web site in that they define a parabolic spring as;
    "Basically a HST Parabolic Spring is a spring that consists of two or more leaves. The leaves touch only in the center, where they are fixed to the axle and at the outer ends, where they are fixed to the vehicle. In between those two points the leaves do not touch each other as they do with conventional leaf springs." (if you placed the same Teflon pads between conventional leaf springs you would achieve the same effect!).
    Where as the true definition is more like "....the leaf is tapered, from the center (thick) to the outer ends (thin). This tapering is parabolic..."
    Have I made this more confusing or less??
  5. #25
    Join Date
    Dec 2005
    Location
    Sandy, UT
    Posts
    6,172
    Quote Originally Posted by Martyn
    Kurt, I'm not certain that parabolic springs reduce friction between the leaves. I think the use of the Teflon pads in this case achieves this. It's a little confusing on the web site in that they define a parabolic spring as;...
    Yup, all part of the accounting for the friction I was referring too
    OME for example uses greasable teflon pads at each spring end. After a few years of use they can start to wear thin, simply replace them with new ones, under $10/springs
    Kurt Williams
    Cruiser Outfitters
    Join us on Facebook
  6. #26
    Join Date
    Mar 2007
    Location
    The Nanny State
    Posts
    5,726
    I think that the damping was off or mis-matched in those who complained of instability with the parabolics. Then again, everyone has their own definition of what is 'unstable' so a qualitative analysis is sort of doomed from the start.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
