Page 6 of 6 FirstFirst ... 456
Thread: HI LIFT AS A WINCH?
  1. #51
    Join Date
    Apr 2010
    Location
    Maricopa, AZ
    Posts
    284
    No need to travel or lose the sleep. That was one of my trucks we tipped in the demo....
    It is/was a 96 SD, 5spd with cloth seats and no sunroofs in 'Expo' White as well!!
    Ian Gregory
    Current LR Stable: 97 D90 ST #1008, 94 D90 SW #1887 (Project), 98 D1 LSE
    Memories of: 84 RRC Vogue 4dr, 93 RRC Vogue SE, 84 Ninety 2.5NA SW, 86 Ninety 2.5TD TC, 96 D1 SD
  2. #52
    Join Date
    May 2008
    Location
    Phoenix, Arizona
    Posts
    358
    You must have installed a new winch and battery on the Disco to do the demonstration on the three point self-rescue using the land anchor.
  3. #53
    Join Date
    Aug 2009
    Location
    In the oven...aka Tucson
    Posts
    356
    Let's just say thank god for plasma cutters and welders...
    01 D2 FZJ80 axles ARB/Detroit 37" Iroks, (F)14" 9100 Coilovers 14" (R)14" FOA Coilovers 1.6 lt230 PSC hydro steering
    96 D1
    1983 110 RHD Pick up
    KF7EMF
  4. #54
    Join Date
    Apr 2010
    Location
    Maricopa, AZ
    Posts
    284
    The Disco wasn't/isn't quite the junker you'd think. Some of the interior parts are gone but if we'd put an under hood fuse box, exhaust Y-Pipe, a couple of cooling parts, fluids and some gas in it we could have driven it on and off the field. Would have made a few noises as the trans is toast but it drives.
    All the rolling didn't really do much to it. A slight crease in the roof from a strap, front fender pushed in slightly and some minor dents in the doors was about it other than a very crushed side mirror. No broken window glass or anything. Would have been different if we'd done it in a rocky or uneven area such as in a real rollover of course but in the grass field it came out of it quite well.
    We drained it of all fluids before so as to avoid making a mess we'd have to clean up so driving it on and off was dropped as an option. Winch mount was temporarily welded and bolted to the frame rails and the bumper, grille, lights, etc. removed to do so. New cheap disposable battery was fitted and direct wired to the winch because of the missing fuse box.
    Here are some pics from a real (unplanned) rollover. That’s actually the same D1 that is being used to pull the truck over in the demo (karma eh?). A bit worse for wear but it drove home. Most rollovers on the trail (at least here in the SW) are very slow and do little more than panel and glass damage like this. Most injuries come from occupants not wearing their belt and being thrown around or being hit by unsecured contents in the vehicle flying around.
    Attached Images Attached Images
    Ian Gregory
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
