Originally Posted by
Danimal
It is not listed as an "option" on the Tacomas, but rather part of a "package". That package is the TRD Off Road package. I've never heard of the locker coming from the factory on a base or SR5 truck.
Of course, the real value of the off road package depends on your intended use. If you won't be venturing off road much, the regular 4WD Tacoma seems very capable. I personally have owned another Toyota with the locker and found it invaluable so I bought the off road package. As it turns out, I was much more impressed with the A-TRAC feature than anything else on the package. The various traction aides (not just the locker) that come with the package are excellent, and I wouldn't buy a Tacoma without it. That's my opinion.
I drove the truck off the lot with a 2,000 lb trailer and roughly 500 lbs of stuff in the bed. I had about 2" to the bump stops and never hit them on my 8 hour drive with that set up. Funny enough, I've been hitting the bump stops lately with a truck full of adults and an empty bed... I'm thinking the springs have broken in causing this. The TSB is looking pretty good to me right now. My truck is a 2011 and the TSB is available if I feel it's needed. Otherwise the suspension is great - I'm very impressed with the ride on-road. The off road flex leaves something to be desired, but that's typical of a stock truck.
I also want to point out that the TSB springs help a bit with capacity, but I've heard that they don't change things drastically. I'm thinking if you're planning on towing a car hauler from time to time, you may want to consider something like air bags.
Dan
