Page 1 of 2 12 LastLast
Thread: Yet to be named Power Wagon Build Thread
  1. #1
    Join Date
    Oct 2011
    Location
    San Antonio Heights, California, United States
    Posts
    796
    Default Yet to be named Power Wagon Build Thread
    I have a couple of posts in various places on my "build" not that I have done much yet. It will be a slow process. Just a little back info on the truck, it is a 2006 Power Wagon, I purchased it all most exactly a year ago with 74k miles, and it now sits at 105k miles. I run 100 miles round trip to work, and take it out every weekend I can. I will copy my Snorkel install into post 2, and put some of what I have done in the last week to post 3
    and if you have a suggestion for a vehicle name, I am all ears.
    2006 Dodge Power Wagon
    1979 Yamaha DT175 Enduro
    Kilo Juliet Six Delta Zulu Zulu
    EMR (Emergency Medical Responder) Certified via San Bernardino County Fire
    San Antonio Heights C.E.R.T Founding Member
    San Bernardino National Forest OHV Volunteer
    Build Thread http://www.expeditionportal.com/foru...61#post1083061
  2. #2
    Join Date
    Oct 2011
    Location
    Posts
    796
    Default Airflow Snorkel
    The original thread is at http://www.expeditionportal.com/foru...gon?highlight=
    I got an airflow snorkel for Christmas, and installed it on Friday. I was rather nervous about doing the install. Looking at the instructions it did not look to difficult, but the idea of drilling a 4" hole in the fender really made me nervous. Well, it all went well, and the hardest part was pulling the trigger on the drill. It took me a little over 4.5 hours to do, but now that I have done it I think it could go much faster. I just took my time and made sure I had it right.
    This is the template cut out and laying on my living room floor
    One last shot with the fender and stock intake still intact
    Template taped to the fender
    Drilling the 1/4" pilot holes, 6 in all
    This is where it got a pit scary
    It came out pretty good, I did have to file it a bit to clean it up, but the instructions said I would need to
    All of the holes except for the A-pillar drilled
    a quick test fit, the instructions tell you to open up the top two holes larger, I tried to get away with leaving them smaller, but it bound up a bit and did not sit flat.
    fitting the airbox with the new fitting and hose. I did not assemble it the way the instructions said. The instructions tell you to put the fitting on the box, put it in place, put the snorkel on, put the elbow on the snorkel and then try to fit the flex hose between the two. What I did was take the bracket that holds the air box off and put the fitting and hose on the airbox. With the bracket off I was able to put the airbox, fitting and hose in place all in one piece, bend the hose down through the wheel well, put on the elbow fitting, then slip the bracket up through the wheel well and bolt it all down. I then put the snorkel on and snapped the elbow into place on the bottom of the snorkel
    the rest are a few shots of it finished
    btw, I know the truck is dirty, and scratched, but I think that is how a power wagon is meant to be.
  3. #3
    Join Date
    Oct 2011
    Location
    Posts
    796
    Default Leer Camper Shell
    When I purchased the truck it had a hard fiberglass tonneau that was installed at the dealership. It was a nice selling point for me, but I quickly found it did not really suit my needs. It did the job, but not the way I wanted. I decided I wanted a shell, but everything I found was either the wrong color, or more then I could justify spending. Well, I finally happened across one on Craigslist and was able to pick it up a week ago Thursday (the night before Desert Rendezvous)
    Here it is on the truck about 10mins after picking it up in Big Bear
    Last week at work I was able to get a prototype sleeping deck built and painted, and I put some carpet on it yesterday.
    with the tailgate closed
    with the tailgate open (holds 4 milk crates in the back section
    Flip open section at the front
    I have already learned some things I don't like about this build that I will change for the final build. This was just to get something back there to allow me to try and it and see what worked for me and what does not. So far, the final build will be lower, and I will switch to something other then milk crates. I would like to get it closer to the height of the wheel wells. The compartment at the front will either hinge from the sides, or be lift off trap doors, not the way it is now, and I will build side pieces to go over the wheel wells and relocate the axe and shovel (most likely to the top corners of the shell.
  4. #4
    Join Date
    Aug 2005
    Location
    Calgary, Canada
    Posts
    3,886
    Great job! I remember my first snorkel install. It took me over an hour to drill the first hole. I must have measured it 50 times.
    Based on this pic, here I my name suggestion: BISON.
    Pete Hartl - VE6PGH - 0VRLAND
    EXPEDITION = (Encounters + Adventures + Experiences) x YOU
  5. #5
    Join Date
    Oct 2011
    Location
    Posts
    796
    I had this mount on the cab with the tonneau cover
    It worked great for my CB antenna and some KC lights. Putting the shell on, this bracket no longer fit, so I relocated the KC lights behind the grill
    and moved the CB antenna to the Driver side Hood
    I have 2 pair of the kc lights, but the way the truck is I just could not get all 4 to fit. There are brackets in the way on the driver side. I will either need to build a bracket put 2 of them in the top half of the grill, or put a light bar on the front. The truck is already on the large side so i was trying to avoid the bar, but think that may be the route I take. I am also not real thrilled with the antenna on the hood. I keep catching it out of the corner of my eye and so far am just not used to it. I plan on a rack on the shell that will allow me to move the antenna back up top, and when I can finally do a custom bumper I may be able to work in a solution for the lights, but a bumper is still a long ways down the road.
  6. #6
    Join Date
    Jun 2009
    Location
    Who knows
    Posts
    395
    I looked at it and thought: snuffalufagous.
    Cool truck!
  7. #7
    Join Date
    Feb 2011
    Location
    N40° 8.7217', W075° 12.8527'
    Posts
    100
    Nice PW. I like the direction it is taking so far. Where did you get the original HMBL mount for the fogs? That's pretty darn slick!
    KB3USY
    2002 Mitsubishi Montero Sport XLS
    Access XCL 26'r-SRAM drivetrain XC MTB
    KHS xc-304 Shimano drivetrain, suspension by X-Fusion and Manitou Full-squish MTB
  8. #8
    Join Date
    Jun 2010
    Location
    Southern California
    Posts
    214
    Nice truck! I swear I saw this beast at REI week ago. I would have been the guy standing in the parking lot staring in a dreamy sort of way. Love the Dodge trucks and yours is a great specimen!
    2010 Toyota Tacoma
    2004 Specialized Epic
    Good leather boots
  9. #9
    Join Date
    Oct 2011
    Location
    Posts
    796
    That was me at rei, I replied to your post in the spotted thread. It is at rei on a pretty regular basis.
  10. #10
    Join Date
    Sep 2012
    Location
    Arizona
    Posts
    108
    Hmmm that seems like a not so good place for your high lift, it will get very dirty there and might not work well when you most need it....just thinking out loud.
    Retired Navy Chief (Viet Nam, Persian Gulf), Communication Sergeant, Verde Search and Rescue.
    http://photocamel.com/gallery/data/6150/2154.jpg
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
