Page 1 of 6 123 ... LastLast
Thread: My new '87 Ramcharger build thread
  1. #1
    Join Date
    Aug 2011
    Location
    Gerber, CA
    Posts
    403
    Default My new '87 Ramcharger build thread
    Good day all,
    Thanks for reading through this post. I purchased the truck with the intent of building a multi-purpose truck to serve needs of the ranch, family camping, trailer hauler and sometimes driver.
    To begin with, I ditched the broken bug deflector as the first mod. Then we had a week plus of windy rain and nothing happened.
    When I got the RC home:
    Today was the first sunny day in seemingly forever, I broke out the tools, and wrenched on my own junk for me. The first orders of business were: 1. removing the early 1990s tires and preparing for newer rubber, 2. inspecting springs, shocks, and sway bars to find the source of bump steer on the street, 3. inspect brake and axles, and 4. to rid the truck of the redneck rear bumper in prep for something more useful.
    Here are some cluster pics to mull over.
    Tires:
    Steering and suspension:
    Bumper and sliders:
    In particular:
    1. The very old tires are starting to delaminate along the sidewall and one sustained fatal damage while briefly on a tow dolly. The turbine wheels look pretty good, but with 6-lugs, won't be able to replace the 5-lug turbo wheels.
    2. The shocks are all shot and leaking. Replace as needed.
    3. The driver's side knuckle has a raised steering arm, but looks like it was meant for a 4" lift, not the 6" lift installed...cross-over steering likely will solve this.
    4. The rear lift was performed with stacked blocks for a total of 7.5 inches over the axle and these will definitely be replaced with Superlift (or similar) 6" springs.
    5. The front and rear sway bar links do not let the bars ride level, rear bar to be removed.
    6. The rear bumper mounts were bent and no longer safe, allowing the bumper to flex when loaded with a trailer.
    7. The so heavy I have to drag it around Iron Mule folding crane bumper will be a simple install and give me the ability to lift things to the roof or simply up. This bumper has a 1500 pound winch and is of heavy enough construction that I can probably add a swing out carrier system to both sides...tires and fuel.
    8. Montero Gen I LWB sliders are a perfect length for a Ramcharger, thanks Ray!!
    Just a beginning, but here we are.
    Russell
    1987 Dodge Raider - Roxy
    1988 Mitsubishi Mighty Max with Starion turbo - Pearl
    1987 Dodge Ramcharger LE - Ryan
    19-something M100 trailer - Darrel (ict)
  2. #2
    Join Date
    Aug 2011
    Location
    Gerber, CA
    Posts
    403
    The Ramcharger is an '87 LE model with 360, automatic and all the trimmings. The CAD front axle and 3.21 gear sets are not preferred, and will be eventually upgraded to 3/4-ton pieces.
    As to supporting the rear bumper, I will have some modifications to the existing brackets to contain bolting connections along the bottom of the frame. There are cross members and the fuel tank in the way of bracketry over the top of the frame.
    My first mod was completed this afternoon, replacing the ancient all terrain tires.
    Then it was time to make dinner.
    R-
  3. #3
    Looks like a good start! I've spent a lot of time in RamChargers, and they are certainly capable rigs. It already looks much better, and i'm looking forward to watching your progress.
  4. #4
    Join Date
    Oct 2008
    Location
    Whistler BC
    Posts
    1,961
    I love what you've done with the paint! It can take decades to get it just right! (I'm serious). Too bad the turbines are six bolt, they look right on that rig...
    '98 Dodge 3500 CTD NV4500 complete with a crap load of goodies. "Bought, not built"
    '11 Rubicon Unlimited OME heavies
    '07 Adventurer 10T
    No kids, 3 dogs, many surfboards...
  5. #5
    Join Date
    Aug 2010
    Location
    Pueblo, Colorado
    Posts
    103
    The rig is looking great!
    One suggestion would be to a shackle flip on the rear and use the stock springs. It Makes for a smooth ride and a very flexy suspension.
    Plus it is very inexpensive. All you need is a set of spring hangers from a donor Dodge truck and drill some holes.
    http://www.flickr.com/photos/29877403@N03/
    '01 Dodge 2500 CTD, mostly stock.
    "whether you think you ‘can' or you think you ‘can't': either way, you're right." Henry Ford
  6. #6
    Join Date
    Sep 2007
    Location
    Conifer, CO
    Posts
    1,959
    Have fun with it, those are great rigs. I wish my dad still had his.
    '92 Range Rover
    '93 Range Rover LWB
    '71 Mercedes 220 Diesel - The daily Beast
  7. #7
    Join Date
    Aug 2011
    Location
    Gerber, CA
    Posts
    403
    @ Colorado Bill,
    The shackle flip is a definite possibility. I wonder if the current rear springs are sagged, as on the jack stands, the springs are flat with all leaves touching. I am hunting now for a 3/4-ton Dodge 4x4 to scavenge the axles as you've done. On the last Dodge that I lifted, I used 4" Rancho front springs and 5"-ish Superlift rear springs. With a service body granted, the chassis was level. My buddy wanted the truck because of the rotating beacon and was relentless until I sold him the truck. He attended a Jeep run with the full size and showed them how a Dodge wheels...until the rear u-joint mount brake on the pinion shaft.
    Based on my experience with the Superlift springs, I was very happy with the product. I plan on towing a travel trailer now and then, and thought I may go with the 3/4-ton springs for a little additional support with 1 additional leaf per pack and significantly more arch. The spring pack on a D300 I looked at today was impressive in the visual lift gain, but I know from experience with a '77 W300 that there is no flex to these packs.
    Posts on RCCentral will guide me in the case of a shackle flips.
  8. #8
    Join Date
    Oct 2008
    Location
    Whistler BC
    Posts
    1,961
    I saw a sweet silver/charcoal RC at the gas station today. It was really clean with nice turbine wheels. I was going to ask him if you could have the wheels, but he kinda looked like a toad and I was afraid!
    '07 Adventurer 10T
  9. #9
    Join Date
    Aug 2011
    Location
    Gerber, CA
    Posts
    403
    The blade wheels are growing on me. I like these rims, in particular, because they have the steel seat for the acorn nuts. The turbine wheels use the mag nuts, and I think I've had my fill of those for awhile.
    I appreciate the efforts, but don't need to take on a toadie. Your safety first!
  10. #10
    Join Date
    Sep 2010
    Location
    Copenhagen and B.C.
    Posts
    1,256
    Excellentprogress on your Rancharger, Rexin! I cant wait to see that truck all finished and out 4 wheeling.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
