kb7our
I have this used stove http://www.amazon.com/Ducane-F7011013-Firelight-BBQ-Campstove/dp/B0000775FH/ref=cm_cr_pr_pb_t that I would like to provide to a wounded veteran of the Iraq or Afganistan war at no cost. The old link tells you pretty much what you might want to know about the unit. It is complete and in good condition with all the parts and a nylon shoulder case. This is a pretty heavy duty stove I have had for several years and no longer need. Could make for a nice camping setup as it has both BBQ and 2 burner capability and is of pretty decent quality. Just keep in mind the two halves work together so you need a large enough space to open up the unit such as a protected top table as there is some heat below the BBQ side (there is a plate with legs that sits underneath that side to keep most of the heat off the table surface). The unit is somewhat heavy at around 15 lbs. Should last many more years I would think. Regulator is low pressure 5 psi. If you are or know a wounded veteran you can deliver this stove to I can bring it to OE12 or come get it in Phoenix. I prefer not to have to ship this out if possible. My only requests are that this unit NOT be sold and that it gets to someone who could really use it. Consider this a little thank you to the Portal and of course to our Wounded Warriors.
PM if interested.
Wade
PM if interested.
Wade
