Another Hummer Trailer Build
cyclic
12v conversion is an easy job on them. Basically just swap bulbs. Big decision for you is how you want to connect to the pulling vehicle. They make a harness adaptor, you could swap the entire assembly to the harness box, you can cut the mil end off and put a 7 lug end on it. I went with removing the end and replacing it with the 7 pin end. I will eventually also convert to electric bakes, but not in a hurry.
WonaWarrior
