2007 Chevrolet Trailblazer SWB
Drivetrain Specs: 5.3L, 4WD, 3.42, G80
Suspension Modifications:
- 1" rear lift blocks
- Airlift 1000 rear airbags
- MarkMC front 1/2" top spacers
- "87" front springs
- Bilsteins all around
Wheels / Tires: BF Goodrich All-Terrain T/A, in LT245/70-17 Load Range E. Stock wheels with no spacers/adaptors
Exterior Modifications:
- GM fiberglass fuel tank / T-case shield
- "Wife-Resistant Running Boards" for the wife (Previously her DD / field work vehicle)... 2" x 6" x 3/16" boxed sliders, mounted on 2" x 2" x 1/4" legs, that are welded to load spreading plates, welded to the frame.
- One each of my (MDB Fabrication LLC, AKA "MTA") bumpers, radiator skids, and oil pan skids:
- Got rid of the stock resonator, and welded in a piece of 2-3/4" pipe and welded that to a 3" chromed tail pipe.
Engine Modifications: 5.3L V8... None needed
Interior Modifications: Hooked into rear seat cig. lighter wiring and added a 2-pin SAE connector to plug in inverter. This frees up the rear lighter port, is a more secure connection than a lighter port, and allows the use of said port while rear seats are down.
Recovery Equipment:
- 48" Hi-Lift jack - http://www.hi-lift.com/hi-lift-jacks/all-cast.html
- Off-Road Base - http://www.hi-lift.com/accessories/off-road-base.html
- Lift-Mate wheel lift hooks - http://www.hi-lift.com/accessories/lift-mate.html
- Off-Road Kit for Hi-Lift - http://www.hi-lift.com/accessories/off-road-kit.html
- Jack repair kit - http://www.hi-lift.com/accessories/fix-it-kit.html
- Smittybilt XRC-10 winch
- Snatch block
- (2) 6' "tree saver" straps
- 20' of 3/8" Grade 70 transport chain
- 2" x 20' static "tow" strap
- 2" x 30' dynamic "extraction" strap
- (2) 3" x 30' dynamic "extraction" strap
- 3" x 20' dynamic "extraction" strap
- 2" receiver shackle mount for rear and front (plus shackle mounts on bumper)
- A bunch of 3/4" shackle mounts
- 4' of 3/8" grade 70 transport chain with hooks on both ends (for wrapping around frames of vehicles without shackle points)
- Extra hitch pins
Electrical Modifications:
- Driving lights - In the bumper, Pro Comp 55W "spot" beam lights. When they're turned on, they turn on and off with the HIGH beams.
- Fog Lights - Also in the bumper, turned on and off by themselves
- Cobra C75-WXST CB Radio, and associated antenna (seen below)
- Tekonsha P3 brake controller (install here: http://www.offroadtb.com/articles/how-to-guides/trailer-brake-controller-install/ )
- Scangauge II
Recovery Equipment:
- Snatch block
- Extra hitch pins
- Scangauge II
