Page 1 of 4 123 ... LastLast
Thread: Putting POWER to the trailer.
  1. #1
    Join Date
    Jul 2011
    Location
    Maryland
    Posts
    754
    Exclamation Putting POWER to the trailer.
    I need some advise on performing this operation. I am melting wires and fuses left and right.
    Setup:
    I have one deep cell Marine battery.
    I have attached to the trailer a fusepanel.
    I keep burining wires when I wire the lights up?
    Do I need to have a fuse between the battery and the fusebox?
    Current Configuration:
    I have one battery grounded to the trailer..
    I have the positive wire from the battery lead to the fused junction box.
    I have the box grounded to the frame of the trailer as well.
    When I place the tester light on the wires from another tiedown in the box it does not have power.
    When I place the tester light on the power feed it works. So how do I isolate the wires . Isnt that
    what the fuse box is used for? I keep blowing fuses and burning the "test " light.
    The goal is to have a few interior (led lights,and a water pump, ) powered by the battery.
    Thanks,
    Craig
  2. #2
    Join Date
    Nov 2010
    Location
    Middle of Nowhere, Outer Skin of Space Ship Earth, 1 A.U. from Sol, Outskirts of Milky Way.
    Posts
    2,087
    The purpose of a fuse, is to protect the wire by melting before the wire does. Every circuit should be protected by a fuse. The fuse normally goes in the "hot" wire, so that when the fuse burns, the entire "circuit" (hot wire (+) / load / return wire (-)) goes dead.
    There should be a hot wire from the battery to the fuse block - that wire should be protected by a fuse or breaker.
    There should be hot wires coming out of the fuse block to feed various loads - each hot wire protected by a fuse in the fuse block.
    There should be return wires from the loads, to the negative terminal on the battery. These do not normally need fuses, since they are protected by the fuse in the hot wire of the circuit.
    Often, the return wires are omitted and rather than running them all the way back to the battery negative, they are connected to the vehicle frame, which is then connected to the battery negative. That way, the frame serves as the return wire for the circuit. This is poor practice, but it generally does work, and it's cheaper and easier than running a bunch of separate return wires, which is why vehicle manufacturers do it all the time.
    Since the purpose of a fuse is to melt before the wire does, the fuse MUST ALWAYS be rated a bit less than the wire. So, say for #12 wire, which is rated at 20a, you would normally use a 20a fuse. The reason you can get away with that, is that the 20a rating of #12 wire is conservative - #12 can actually handle a bit more than 20a, so if the fuse burns at 20a, the wire won't be to the melting point yet.
    The most common reason that wires melt, is that the fuse is rated higher than the wire. This makes the wire melt but not the fuse. The wire is protecting the fuse, which is backwards.
    From what you describe, I would guess either that A) you've got something wired seriously wrong, or B) that you've got loads which are greater than the wire can handle, AND oversized fuses that don't protect the wire. I.e., a 10a rated wire, protected by a 15a fuse and more than 10a of load being fed by the wire.
    A little 12v tester with a lamp in it, should not burn the lamp unless your wiring is screwed up so that when you use the tester, the tester becomes part of the circuit (and the filament in the lamp now becomes a fuse).
    Of course, all of what you describe could also be caused by extremely crappy grounding - like...oh...using the frame or chassis as the power return path...
    Current: 76 E-250, bubble-top, self-contained|couple of old Yamaha enduros
    Previous wheelers: 41 Willys|78 FJ40|78 Bronco|84 Bronco|74 Ramcharger|78 Ramcharger|79 D150 PowerWagon|77 D100|79 D400 dually, converted to 4WD, utility bed, 10' Lance|75 Westy|69 Scout, RHD|bunch of others|bunch of bikes|couple of boats|couple of motorhomes|blah blah|so what|not my idea|just doin' what I'm told|wank wank|this space for rent|candy is dandy|but liquor is quicker
  3. #3
    Join Date
    Jul 2011
    Location
    Maryland
    Posts
    754
    I guess I need to get a breaker or fuse for the battery side. What size of fuse would I put in there? Would a 20 amp fuse be okay to place in the battery side?
    Thanks for the helps.
    Craig
  4. #4
    Join Date
    Nov 2010
    Location
    Posts
    2,087
    The fuse must be the right size to protect the wire. To figure out what size fuse you need - you need to know what size the wire is, and what amperage it is rated to handle.
    Then you know what size fuse you need to protect that particular wire.
    If you are melting the wire from the battery to the fuse block - then you probably need a bigger wire. AND the right size fuse for the new wire.
  5. #5
    Join Date
    Feb 2012
    Location
    USA, Texas
    Posts
    195
    Could you post a photograph of what you mean when you say you have the box grounded to the frame of the trailer.
    Are you saying that simply by placing the test light on the fuse block and it blows a fuse and the light?
    Kevin
    2011 Ford F-150 FX4
    2012 Kamparoo Transcontinental
  6. #6
    Join Date
    Jul 2011
    Location
    Maryland
    Posts
    754
    the test light is just an old turn signal bulb. not an amp meter..
    The fused box is grounded to the trailer. Along with the battery.
    For the battery I used the same ground as the Military used when they had
    the engne and ballasts grounded.
  7. #7
    Join Date
    Nov 2008
    Location
    McCall Idaho
    Posts
    266
    Craig have you recently painted the trailer? If so try putting an external star washer between the frame connection and the cable end. It will bite through the paint to metal.
    Hope this helps.
    P.S. Why did'nt you run the ground straight to the battery along with the positive?
    Brian
    86 Suzuki TinTop Samurai -"Stanley"
    88 Coleman Sun Valley
    92 Suzuki GSXR 1100
    2003 Ford F-350 W/ Custom Aluminum Flatbed
    2002 Montana Mountianeer TT
  8. #8
    Join Date
    May 2010
    Location
    Alberta, Canada
    Posts
    191
    Also how many lights are you putting on one wire/switch and what is the wattage?
    Here is how I wired up every vehicle I have ever done with lights but in your case you will need a fuse panel. I am very fond of the Blue Sea panels myself as I find them perfect for my needs.
    I also use relays for each pair of lights I install to reduce the current through the switch.
    My truck build-up ---> 2010 Dodge Cummins 3/4 Ton Crew Cab
    My M101-A2 build up ---> Camping utility trailer
  9. #9
    Join Date
    Jul 2011
    Location
    Maryland
    Posts
    754
    Quote Originally Posted by Backroad Explorer View Post
    Hope this helps.
    Negative on the paint. As far as running the ground straight to the battery not sure why..lol
  10. #10
    Join Date
    Nov 2008
    Location
    McCall Idaho
    Posts
    266
    Just curious,
    I've always run pos. & neg. to the battery for all my accessory Fuse Panels same for radios C.B. or Ham.
    I just don't trust the frame as a ground path.
    Brian
    92 Suzuki GSXR 1100
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
