Page 2 of 2 FirstFirst 12
Thread: How to mount rack on shell/topper - Track or Pad mounts
  1. #11
    Join Date
    Feb 2012
    Location
    West By-God Virginia
    Posts
    6
    Default You can't go wrong with Yakima
    The racktracks are great, I've had them on several vehicles with no complaints. You'll need to buy the tracks, landing pads, towers and bars. Not cheap but it works as advertised. There should be several "How-To" threads here, Tacoma World and probably You-Tube. Basically you'll want to line up the tracks with the ditch moulding on the cab of the truck. Sorry, I know that's vague but check out the links and it will make sense. Hope this helps.
  2. #12
    Join Date
    May 2009
    Location
    Colorado
    Posts
    30
    Quote Originally Posted by Kermit View Post
    Measure twice (three times in my case) drill once...I like to put a dab of silicon in the drill holes too.
    I like to use a tailor's tape measure, since it bends nicely over the curvature of the topper.
    Maybe measure four times. I had tracks installed on my last topper and they either couldn't use a tape measure or simply eyeballed it. As I didn't move the bars around much, I didn't notice it for some time. Sucks to have to loosen up the entire tower just to slide it.
  3. #13
    Join Date
    Sep 2011
    Location
    5mi NE of Hell
    Posts
    178
    Ok, so this is a topper on a 1st gen DC. That makes the topper maybe 55" long on top. The feet of either are about 4-5" wide, so that leaves you with a 50" spread, at best. If your cap has windows, putting extra bars in between wont help much with load capacity. Think about what you would need the bars closer together for. I had a Yakima landing pad setup on my Tundra for 6 years. Never felt I needed to move anything. The bars go on and off in literally seconds. You can, of course mount the pads on tracks, too. In all, I can't reccomend the control towers enough. Either way, you'll need to dill about four holes per side- either about 1 per each 12 inches of track
  4. #14
    Join Date
    Sep 2011
    Location
    5mi NE of Hell
    Posts
    178
    Love my Yakima control towers. On your DC the longest spread will be about 50". Structurally, adding more bars above the side windows wont ad any load capacity. You'll need about 4 holes per side either way. if the inside of your topper isnt carpeted, I can highly reccomend epoxying t-nuts from the inside. For more bar spread, like for kayaks, you can ad a Q-tower bar up front.
  5. #15
    Join Date
    Mar 2006
    Location
    The Great State of Denial (SC if you really want to know)
    Posts
    948
    Check your shell to see if it has a honeycomb section in the middle- many do and you don't want to drill through that; drill outside of the thicker honeycomb area. I used Yakima tracks on mine and have been very happy with them so far (except for the anodizing wearing off). They recommend using a small amount if silicon and not a big blob; my brother worked at a bike shop and installed them and said they didn't have any issues with them installed that way so that's what I did (instead of a big blob). Mine's been on for around six years now with no issues and I carry multiple kayaks (including a couple of heavy sea kayaks) as well as a variety of other stuff.
    Definitely measure several times before you drill. Tape your area to drill and drill a pilot hole then step up to a larger bit in order to avoid chipping the fiberglass. If you have carpet in the interior of the shell use a drill bit stop (or just wrap tape around the bit) so it only goes through the shell- if it gets into the carpet it'll snag it and start pulling it. A second set of hands will be a big help.
    The Yakimas are easy to take on and off- unlock the bases, flip the plate open and lift the rack assembly off. Handy for those longer trips where you don't need to carry anything and want the best mpg possible.
    05 Tacoma TRD, SR5, V6, etc
    1978 VW Westfalia
    2007 Suzuki DRZ400s
    Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?
    Hunter S Thompson
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
