Page 5 of 6 FirstFirst ... 3456 LastLast
Thread: what solar panel to use
  1. #41
    Join Date
    Mar 2008
    Location
    Arizona
    Posts
    1,406
    Quote Originally Posted by rideglobally View Post
    http://samlexamerica.com/products/Pr...ail.aspx?pid=6 ordered ....... thanks dwh
    now i just need to figure out inverter, i like the morningstar 300 recommendation especially the fact that it does not have a fan. i use a small inverter plugged in to my cigarette lighter that fan is annoying. my question is will 300 watt enough for my application? can you tell me what a 300 watt inverter can handle? can it handle a small amplifier, coffee grinder, led lights, small flat screen tv, lap top ..... of course we would not be running all of this at once.... thanks
    I would say get one of the Kill a Watt devices about 20-30 bucks and check your stuff out might be the most accurate way
    my grinder is a large Mazzer so not your normal
    a 24 inch LED lit LCD should be easy but a 42 inch plasma will have issues same thing with the amp really depends
    laptop no problem I would see
    LED lights I know wont be a issue and many can run on 12V since the inverter takes power to work anything you can run on 12V is better IMHO as long as it does the same job of course
    my Snow Peak Reviews & Tweaks
  2. #42
    [QUOTE=dwh;
    Amp...what amp?[/QUOTE]
    Small amplifier for a PA system. We like hanging out in remote villages/reservation. The PA amplifier is connected to inverter, inverter to car battery programs goes on whole day by end of day 3 cars would not start cause of dead battery. .... Be great to help out.
    In any case, from what I am learning here I am getting convince that the Morningstar 300 is sounding like a good option. Saw it listed for $187.
    By the way the samlex cost me $113.
    Thanks
  3. #43
    Default solar installed
    thanks all for your help. here is how i spend my weekend. the solar panel is fix and is potable for those rare times i need to make it portable. that pipe looking thing is marine grade plug in, i am able to unplug the solar panel place it at a remote location, connect to the connector on the roof using an extension cord. the panel can also be tilted 45 degree on the roof when the pop top is not open, i probably got a little carried away with the design but, had fun doing it.....
    the AC battery charger should be here soon..... thanks again
    Attached Images Attached Images
  4. #44
    Join Date
    Nov 2010
    Location
    Middle of Nowhere, Outer Skin of Space Ship Earth, 1 A.U. from Sol, Outskirts of Milky Way.
    Posts
    2,096
    Nice! Don't forget to post an update with some performance numbers. Inquiring minds want to know.
    Current: 76 E-250, bubble-top, self-contained|couple of old Yamaha enduros
    Previous wheelers: 41 Willys|78 FJ40|78 Bronco|84 Bronco|74 Ramcharger|78 Ramcharger|79 D150 PowerWagon|77 D100|79 D400 dually, converted to 4WD, utility bed, 10' Lance|75 Westy|69 Scout, RHD|bunch of others|bunch of bikes|couple of boats|couple of motorhomes|blah blah|so what|not my idea|just doin' what I'm told|wank wank|this space for rent|candy is dandy|but liquor is quicker
  5. #45
    soon as arb fridge strap arrive i will be installing fridge let the fridge run, then on July 3 we are going on a 3 to 4 week ride through Zion, Moab, South Dakota, Kamloop Canada and back, no fix route just some destination.
    my Samlex AC charger also came in today and the morningstar 300 should be here next week.
    will post data and thank again for all your help it has been fun and educational, i know nothing about solar when i started this thread, now it is time to test it on the field see how it works, i will keep posting data.
  6. #46
    Join Date
    Jul 2008
    Location
    Wherever my Landcruiser is parked
    Posts
    548
    Quote Originally Posted by dwh View Post
    x2
    Luis and Lacey - Lost World Expedition Facebook
    Ongoing overland trip from the U.S. to Ushuaia, Argentina in an '87 FJ60. On the road since July 2009
  7. #47
    Join Date
    Sep 2006
    Location
    nomadic man
    Posts
    227
    In the picture with panel, if that is mounted then you might consider raising it up as it's not getting any air underneath and it is recommended that some space be between the roof and the panel.
    Jay
  8. #48
    Quote Originally Posted by jkam View Post
    i will have to do that when i get back from my trip, how much space do you think is best. just got done installing inverter, battery charger, art fridge etc.... will post up some picture soon. been too busy getting ready for the trip. thanks
  9. #49
    Join Date
    Sep 2006
    Location
    nomadic man
    Posts
    227
    About an inch will do, just need to get some air under the panel to help keep it cooler.
    Jay
  10. #50
    Join Date
    Sep 2006
    Location
    Canadian in Colorado
    Posts
    1,063
    In addition a panel or set of panels will help your rig stay cooler in hot weather.
    '12 Dodge 5500 6.7 diesel slightly modified. 14' 3" Alaskan camper (Alaskanabego)
    My camper build: http://www.expeditionportal.com/foru...ead.php?t=9502
    KD0ERY
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
